Team Powers Actium V2 17.5t
Anyone have any experience with these motors? I'm given to understand that they run very hot/high RPM and need to be geared conservatively. Checked out their web site, lots of (pricey) options for these motors, things like tuning rotors and "advanced" end-caps.
What's the deal?
What's the deal?
I just got one and MAN ITS FAST. Easily feels like a tuned down mod motor. If you get one of the updated motors, they have an extra 10* of timing built in. So 40* on the old v2 would be equivalent to 50* on the new v2. That may be why you were told that they run hot. People are actually just running more timing. Mine come off at 152 after a 6 min main w/o a fan, 123 with a fan. I am geared 29/69 for a smaller track with 43* on its end bell. This motor is very fast, and 95% of people at my track run it for 17.5 buggy.
What's the deal?
What's the deal?
The V2 is really fast compared to the V1. The timing on the can was close to the timing I get off the motor analyzer. I initially tried timing at 50 degrees plus with a lower gear ratio, but a couple of racers ( faster than me ) suggested I drop the timing to 40 and run a higher FDR - it works and I get more pop off the turns in the infield. I run a fan and heat has never been a problem - I think max temp I have seen is 145 - 150F, typically it is lower. I'm still really impressed with this motor.
FYI - the sensor board is different in the V1 and the V2 - the V1 works in a V2, but the timing on the V1 board is about 15 degrees higher than the V2
First, thanks for the great info! This is precisely what I was looking for.
I'm currently running a TP Radon Sport V1. How would this motor respond to that ESC and probably zero to minimal degrees timing?
Acquired a used Actinium V2 17.5t. If anyone is curious, the stock rotor is 12.5mm. What I can't confirm is the stock timing setting. I know that the guy I bought it from likes to get as much power as possible, so I'm pretty sure he advanced the timing (32°). Stock picture of the motor shows something more like 12°.
Right now, I am not a super-aggressive driver and I don't push the electronics as a result. So really, even with advanced timing I doubt I'd overheat the motor.
What are the thoughts here? Leave it at 32° or move back to what I think is 12° stock?
