Esc motor. Stutter
I have a lrp ix8 v2 with a reedy 7.5t(sensored)geared 13 54 32p runs good and smooth. Except when trying to mash the trigger at a dead stop just stutters specs say esc has no motor limit. Its in a 2wd sct. Im thinking it maybe sensor wire. Any ideas would be helpful thanks
Are you sure you have all the wiring correct. A on the esc to A on the motor and same with B and C. If so I would check the sensor wire.
It won't be incorrect connection as the previous poster describes as the system works fine when driven smoothly. The issue you describe occurs only from a dead stop start.
If you've changed the sensor wire and still have the same problem it could be a bad sensor board and so if you have another motor try it. If that still doesn't work then it is also possible that it could be the lipo not providing enough initial current to start the motor flat out from a dead stop. However the symptoms you describe points to a sensor issue either the wire or the motor sensor board itself. |
Originally Posted by dan_vector
(Post 14962065)
Try reducing the motor's endbell timing.
Originally Posted by howardcano
(Post 14962445)
| All times are GMT -7. It is currently 01:15 PM. |
