-   -   Drag race specific esc ???? (https://www.rctech.net/forum/radio-electronics/988800-drag-race-specific-esc.html)
Slap 05-30-2017 01:11 PM
So who is gonna step to the plate and give us a esc capable of 2s to 6s drag race specific , no motor limits , ??? Anyone ?
DesertRat 05-30-2017 02:27 PM
That's 1/8 scale ESC territory.
ESC's aren't like the old microswitch stuff where you could just have it switch on for a blast, even if your run is 2 seconds your ESC still has to receive six inputs from the hall effect sensors to calculate and enact three energized windings per rotation of the rotor. At 50,000 RPM this is 5000 inputs and 2500 outputs per second. Not to mention that your ESC's internal power supply for its processor is meant to run within a certain voltage range and 6s can and will overdrive the circuit into burning the board up. I would just get an 1/8 unit and remove the cooling fan and most of the heat sink to save weight.
Slap 05-30-2017 03:41 PM
Well the only 1/8 esc that works the best is the castle esc with 1.24 firmware , anything else just isn't comparable
billdelong 05-31-2017 05:30 AM
Go 8S or go home!
http://www.skyrc.com/image/data/980px_en/1bi5/1.jpg
Slap 05-31-2017 05:41 AM
Originally Posted by billdelong (Post 14941044)
I actually run most on 3s but got 1 on 2s and 1 on 6s I've ran 8s before but more power isn't always the answer , more power means more spinning , spinning ain't winning
billdelong 05-31-2017 05:48 AM
amen to that... honestly I don't drag race but if I did I would go with the highest voltage I could get and use expo to tune out spinning ;)
I would also consider adding more weight to the rear to get more traction too.
Slap 05-31-2017 05:52 AM
Highest voltage equals more weight , and the voltage doesn't mean anything if the esc can't deliver it properly, the hit off the line is where most fall short, it's all about power delivery
