Zero timing esc's
Ok gang, I would like a list of the esc's that meet the following criteria.
1. ROAR approved. 2. Are zero timing. 3. Can not in any way have timing programmed into them. As a bonus, is there one that meets the above and can run on a 1 cell, without an external booster and provide 6v to the esc (built in booster). |
The justock is a zero timing and roar approved. Not sure if there is a 1s version
Originally Posted by thisguy2849
(Post 14933011)
I do not know of a 1s version so no bonus points there. |
I tried this thing called google.
It gave me a whole list of things https://www.google.com/search?ei=6L8...k1._bOirfkT2tc |
Originally Posted by theproffesor
(Post 14933071)
It gave me a whole list of things https://www.google.com/search?ei=6L8...k1._bOirfkT2tc YES!!!:batman: |
Yes Google does give you a whole list of sites on zero timing stuff but not the answer to requirement #3. The ROAR list does specify a esc as zero timing but only in some cases.
Hopefully not a stupid suggestion as I'm not really into racing but maybe this?
https://hobbyking.com/en_us/tracksta...-approved.html |
Originally Posted by blarks
(Post 14933211)
https://hobbyking.com/en_us/tracksta...-approved.html To answer the original OP, I don't know of any ESC that meets all four requirements and is still in production-- nothing that I've tested for ROAR in the last three years or so, anyway. |
Originally Posted by howardcano
(Post 14933319)
That has adjustable timing.
Pretty sure the Fleta Euro has no timing adjustment possible also.
- but - not sure if you are restricted to change the firmware, if you can it can probably do timing adjustment. |
Black diamond 1 cell ..in blinky mode... but i think you will need a booster.. its a advanced electronics..
(Post 14933319)
To answer the original OP, I don't know of any ESC that meets all four requirements and is still in production-- nothing that I've tested for ROAR in the last three years or so, anyway. I wanted to compile a list for a specific class. The general idea was I could specify a single model but that can bite you when it is no longer available. So having options was what I wanted and all I want tech to do is identify the esc and not have to know what pattern or color of lights or sequence. So now the first three are all I need. I will go down the ROAR list again, then check each manufacturer's manual for any indication of a timing method or mode. |
Originally Posted by Skiddins
(Post 14933626)
Not even the Hobbywing Justock?
(Post 14933626)
Originally Posted by TOM MAR
(Post 14933334)
The hobbywing in the link is also very very small. There is also a multi cell version.
Originally Posted by old_dude
(Post 14933644)
Thanks Howard:
I wanted to compile a list for a specific class. The general idea was I could specify a single model but that can bite you when it is no longer available. So having options was what I wanted and all I want tech to do is identify the esc and not have to know what pattern or color of lights or sequence. So now the first three are all I need. I will go down the ROAR list again, then check each manufacturer's manual for any indication of a timing method or mode. HobbyWing Justock XR10 Reedy Blackbox 800Z Tekin RS Gen2 Spec Turnigy Trackstar 60A Sportsman |
(Post 14933655)
Fixed timing is getting pretty rare! Since I have all the data here, I just did a quick scan and came up with the following for 2s operation:
HobbyWing Justock XR10 Reedy Blackbox 800Z Turnigy Trackstar 60A Sportsman |
You left out the Tekin RS spec.
It has no timing adjustment. |
(Post 14933706)
(Post 14933805)
Incorrect! There is actually 4 2 can be programmed, 2 cannot.
You can program several things on the esc. I have 2 of them You Can NOT adjust timing in it. From the page. 1S Zero timing World's smallest & compact ESC. '23.5 g' |
(Post 14933855)
The XR10 Stock Spec 1s has a non-timing profile preset. Timing is locked at zero in this profile. Timing can be added by changing to a different profile. All of this is within the existing software.
(Post 14933865)
Thanks howardcano
(Post 14933875)
That is what i found when i read the manual on the XR10 Stock Spec's. They have a locked mode (as do several others). But take it out of that mode and timing can be programmed.
(Post 14933888)
I guess I need to check closed in tech. I had no idea.
(Post 14933655)
Tekin RS Spec has no timing profile options. The RS Gen 2 does have Blinky and optional timing profiles.
(Post 14934152)
Howard: According to the manual on the Tekin RS Gen2 Spec, it has available timing profiles.
Originally Posted by yzracer758
(Post 14934158)
(Post 14934161)
The Tekin product page states that the Spec is always in non-timing mode, as stated by yzracer758. But the link to the manual is for the regular GenII, which does have adjustable timing. I don't know if the link is incorrect, or that there simply is no separate manual for the Spec version.
(Post 14934161)
Very nice esc. |
There is a zero timing black box:
https://www.amainhobbies.com/reedy-b...c27002/p478558 No adjustable timing. |
Originally Posted by Roelof
(Post 14971744)
| All times are GMT -7. It is currently 06:05 AM. |
