DSB-R+ R10 Stock Connection Problem >
Old 05-17-2017, 03:11 PM
thirtydaZe's Avatar
Trader Rating: 15 (100%+)
Default DSB-R+ R10 Stock Connection Problem
Im having an issue connecting my program box to my ESC. I Hve my programmer updated to version 2.07 as of today, however the problem started last night when i was on version 2.06.
What happens when i plug it in, is it displays the version, but never establishes a connection.
Now, when i plug this in to my r8.1 pro, there is no issue, it works fine.
I have previously programmed the r10 with this box, so it seems to have quit for essentially no reason.
Anyone have a work around for me?
thirtydaZe is offline
Old 05-17-2017, 09:10 PM
Are you using a Orion motor? If not, you must unplug the sensor cable to the motor.
dinosback is offline
Old 05-18-2017, 01:42 PM
BadPanda818's Avatar
Trader Rating: 18 (100%+)
+1 I just disconnect the sensor cable from the motor and plug it in the box with no issues. There are some motors out there that will work without having to remove the sensor cable.
BadPanda818 is offline
Old 05-18-2017, 02:45 PM
thirtydaZe's Avatar
Thank You!
That was the work around, i had no idea. I was previously running an Orion motor so it was never an issue.
Appreciate the help!
