Help- converting Nikko to hobby grade
1 Attachment(s)
Hi, I have a Nikko 1/10 R34 drift car that I have lost the battery and controller to. I realize that Nikko is probably different from actual hobby grade cars, but the chassis and body is just so awesome I wanted to convert it to run with a new battery and transmitter. The problem is that I'm not sure it will work with hobby grade stuff. Does anyone know what I can do to get it going again? Thanks! Info: 27 MHz 3 channels
this mod to hobby grade stuff might work... is servo a 4 or 5 wire? size?
you can use motor.. might be able to use servo.. you will need a brushed esc and a battery..and a radio with receiver.. |
Regarding that trim knob under the chassis I think it is coil servo, probably switching between 3 positions.
I think to make it work you have to rip it all out and mount a servo, ESC and a receiver. Maybe you can find a used electronic set from a Mini-T, when you convert a mini-T to brushless all have to be taken out..... |
1 Attachment(s)
Ok so I have taken all the plastic off and well... it's a mess, nothing like hobby grade looks like. I can't even begin to think about how to put a new esc and receiver in there.
| All times are GMT -7. It is currently 02:16 AM. |
