-   -   Low starting voltage - Tekin data logs (https://www.rctech.net/forum/radio-electronics/986151-low-starting-voltage-tekin-data-logs.html)
Wanderer77 04-29-2017 05:23 PM
I have 3 different Tekin ESC's (2 RSX, 1 RS Gen2) in 3 different vehicles, and whenever I check my data logs I never see 8.4 v as my starting voltage. Generally, I see ~8.2 v as the starting voltage when I turn on the cars for the first time.
I have a Hitec x4 AC plus charger, 4 SMC and 1 ProTek battery that says they are fully charged and at 8.4 v. Whenever I randomly check with my HiTec Lipo checker it also says fully charged and 4.2 v per cell. Still whenever I check my data logs I still only see ~8.2 v when I switch on.
I have no fans on anything even the RSX ESCs.
I've tried unplugging my transponder, and tried lowering my BEC voltage to 6 v, but nothing has any affect.
Does anyone else check their starting voltage in their data logs? What do you see?
Where's my .2 v, I want my .2 v! lol
Thanks.
Mirkinator 04-29-2017 08:47 PM
Voltage will drop anytime you put any kind of load on the cells. There is no load when you charge them and should show a slightly higher voltage. Ive never checked my batteries once they are connected though, but i assume thats what is happening
Wanderer77 04-30-2017 09:23 AM
Maybe, but I'm not sure. I don't charge with my ESC plugged in, and I've wondered if it has to do with the capacitor charging up when I plug the battery in. I see some guys charge with alligator clips on the battery leads while the ESC is still plugged in, but that has always made me nervous.
I've read through a bunch of the Tekin data logging and have seen screen shots of cars starting up with 8.4 v, but I've never seen it myself. I don't worry about it in my mod motor vehicles, but the super stock class at my local track is very competitive and I'm looking for every .1 sec I can get.
Thanks for any input!
gigaplex 04-30-2017 03:52 PM
It could just be that the voltage sensor in the data logger isn't particularly accurate. The one in my Hobbywing regularly reads around 0.5V too low.
