High voltage air ESCs for speed runs?
On my speed run mini 8ight T, space is at an extreme premium. I have seen some speed run vids on YT (I believe by Nic Case) and he shows some still pics of his cars. You can see the ESC is a standard Castle AIR unit, which is much smaller than the car unit.
What are the disadvantages of using an air ESC? I think the only 'feature' I need is braking... everything else can be skipped for speed runs.
Any thoughts?
Any thoughts?
You would still have a brake, but you'd only have one value. It wouldn't be a proportional brake like on a car ESC. If not enough, you'll run out of range (or worse). If too much it'll lock up the wheels and spin out. Step up the speed slowly to get a ballpark figure of what percentage you'll need to use. Also, since it doesn't have reverse the ESC will arm at the full brake position on a pistol grip transmitter, and neutral would be 1/2 throttle. There's a product called a PiStix you can buy that goes between the ESC and receiver that moves the trigger position to neutral. Either that or if you have a very highly programmable radio you may be able to use the trim/subtrim/travel features to get the PWM signal over far enough that the ESC arms with the trigger in neutral.
Just got a new esc and went out for some speed runs with the default brake setting of 50%. First time I hit the brake while at speed the front suspension compressed and the truck violently cartwheeled down the block... while my transmitter beeped to warn me that I was exceeding the defined 100kph speed limit. Lol
Second try, less brake, ended up front flipping onto the roof and sliding down the block for a couple hundred feet.
Only having full brakes would be.... interesting. Probably kinda dangerous too.
