Like Tree80Likes
Futaba 7PX
Old 07-21-2019, 06:29 AM
  #571
Garet Jax's Avatar
Trader Rating: 96 (100%+)
Look if the servo mode is set to SR, if so change it to normal
Can't I just disable SR on the individual channels or do I have to use non-SR from the start? Does it matter which channel I use for the ESC and which one I use for the steering servo? Thanks.
Garet Jax is offline
Old 07-21-2019, 10:49 AM
  #572
Roelof's Avatar
You can leave the transmitter in SR mode but be sure the channels are set to normal
Roelof is offline
Old 08-06-2019, 09:46 AM
  #573
Trader Rating: 26 (100%+)
Is there an option trigger module for the 7PX that will shorten the distance from handle to the trigger? I already have the trigger module adjusted to its closest point and using the smallest handle grip but could still use a shorter finger reach for better ergonomics. Ideally, the trigger should be within a relaxed reach.
The trigger throw on the 7PX is much further away than the M17.
MDawson is offline
Old 08-13-2019, 12:05 AM
  #574
Couple of Qís
Playing around with a drift car and have a gyro in it now two things
1) the Gyro is a Futaba GYC and when you connect it up with remote gain the trim on the gyro becomes servo limit trim (without remote gain it defaults to 50%) now if this controls the servo limits does that mean this is now my end point control rather then on my 7PX (which Iíve set the endpoints and prefer the accuracy of this method rather then a little trim)
2) now Iím running a S.Bus receiver and Gyro but a non S.Bus servo can I config the Rx and gyro in S.bus or would I need an S.bus servo as well?
Heres the manual
https://www.rc.futaba.co.jp/english/...l/gyd450_e.pdf
Hope that makes sense?
EvilR2.0 is offline
Old 08-22-2019, 04:17 PM
  #575
jdearhart's Avatar
Trader Rating: 15 (100%+)
Need to replace the battery in my 7px and was wondering if there was a bigger life pack than the Protek?
jdearhart is offline
Old 09-03-2019, 12:10 AM
  #576
morgoth's Avatar
Could some weight his 7px with the battery installed? I'd like to compare it with to my Sanwa M11x to see how much lighter it is.
morgoth is offline
Old 09-03-2019, 03:13 AM
  #577
I think the Protek one is around 2000 my Arrowmax one is 2400mah
EvilR2.0 is offline
Old 09-03-2019, 03:16 AM
  #578
I can weight mine later but itís the 7px with the optional CF handle and alloy wheel mount fitted.
EvilR2.0 is offline
Old 09-03-2019, 07:48 AM
  #579
My 7px come in at 635g with Arrowmax life battery fitted, and the above accessories.
EvilR2.0 is offline
Old 09-04-2019, 07:23 AM
  #580
morgoth's Avatar
Thanks a lot! I'm going to weight my M11x and see how they compare. I think the M11x will be a bit heavier.
morgoth is offline
Old 09-04-2019, 07:52 AM
  #581
As said mine has the CF handle (which doesnít add much) but I do have the aluminium steering housing (black with polished edges) the Tetsujin wheel wasnít on when I weight it.
EvilR2.0 is offline
Old 09-05-2019, 02:53 PM
  #582
Trader Rating: 30 (100%+)
Looks like Futaba just lowered the USA price for the 7px from $700 to $600. But it’s still can be has for $550 shipped with 2 receivers from Asia distributors.
riceball777 is offline
Old 09-10-2019, 12:39 PM
  #583
What is the correct android app for software updates? I see a "TMA-1" app, but am not sure that's it.
JerseyGTS is offline
Old 09-11-2019, 10:39 AM
  #584
TurnNBurn's Avatar
Originally Posted by riceball777 View Post
Looks like Futaba just lowered the USA price for the 7px from $700 to $600. But itís still can be has for $550 shipped with 2 receivers from Asia distributors.
Hmm, so it just looks like they now offer the 7PX with either the 334SB, or 334SBS-E for $599, but no longer offer Tx only, which was previously sold for $599 only (at least from the retailers Iíve checked) - trying to unload some unsold Rx inventory, perhaps? Iím kind of decided on what radio I plan on buying, but a 7PX Tx only option at a lower price as well would have been at least something to think about.
Iím sure itís been mentioned here, but personally, I would avoid buying a radio from overseas - I donít think you will get any support/repairs here in the event something happens to it if they find itís an Asian S/N. But again, that would be a personal decision.
TurnNBurn is offline
Old 09-22-2019, 07:53 AM
  #585
soulcoma's Avatar
Trader Rating: 37 (100%+)
Can anyone tell me how to set failsafe and idle up ? I set button to idle up and I turned on failsafe but I can’t figure out how to change the servo position
soulcoma is offline
