Like Tree61Likes
Futaba 7PX
Old 04-18-2019, 07:52 AM
  #496
Roelof's Avatar
If you have issues during practise, just unplug it to see if it works. If so it is wise to search a spot not that close to electronics.
Once I had seen a continious glitching car. While the transponder was mounted not close to the electronics and was working fine on the counting system it seemed the transponder was causing it, a new transponder did solve the issue.
And yes, it can work fine when it is on top of a servo or receiver but still it is no good idea to place a transmitter close to a receiver.
Always try to run w/o transponder if you have glitching/range issues.
Roelof is offline
Old 04-18-2019, 10:24 AM
  #497
Default 7PX limited on Ssle at rcmart
Rcmart is selling 7PX limited radios with 2 receivers for $679.00. They only have 8 left in stock.
slot113 is offline
Old 04-21-2019, 09:32 PM
  #498
mbykerman's Avatar
Trader Rating: 46 (100%+)
Any good leads on screen protectors for the 7PX?
mbykerman is offline
Old 04-22-2019, 01:10 AM
  #499
Roelof's Avatar
I believe Hiro Seiko had made them as also Futaba has them. Or you just go to a smartphone shop......
Roelof is offline
Old 04-22-2019, 05:05 AM
  #500
mbykerman's Avatar
Thanks for the input.
Old 04-22-2019, 03:29 PM
  #501
Here's what I found after talking to bobby at Futaba.
SBUS SR Modes for your Servos.
After you bind up your SR receiver, and you are setting your servo to SR mode through an SBUS connection, you will get prompted to set the mode to 1, 2, or 3.
1-3 represent increasing speed and torque. However, aside from the CB700, most of them are only capable of setting 1, anyway.
If you have a CB700, though, enjoy!
jon003 is offline
Old 04-22-2019, 05:11 PM
  #502
So I just got the cb700. I can get this one to sr mode 3 and it will be faster?
riceball777 is offline
Old 04-23-2019, 02:47 PM
  #503
I believe that in SR mode, it makes the fastest torque and speed settings available.
jon003 is offline
Old 04-24-2019, 01:19 PM
  #504
Trader Rating: 33 (100%+)
i been using the CB700 since i got the 7px, didnt know what the 3 modes were. i will try the different settings soon.
dgrobe2112 is offline
Old 04-24-2019, 01:24 PM
  #505
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 89 (100%+)
I imagine the OS Speed Servos when available will give the 700 a run for its money! Unless they were discontinued for a reason!
1/8 IC Fan is offline
Old 04-24-2019, 01:42 PM
  #506
have you seen the stats on the OS vs the CB700 servo.. cmon man.. not even close..
OS R1 specs
6.0V 7.4V
Speed: 0.13 sec/60 0.10 sec/60
Torque: 219.5 oz-in (15.8 kg-cm) 264 oz-in (19.0 kg-cm)
Rated Voltage: DC6.0V - 7.4V
Operating Voltage: DC4.0V - 8.4V
OS B1 specs
SPEED: 0.06 sec/60 at 7.4V
TORQUE: 341.6 ozf/in (24.6 kgf/cm) @ 7.4V
CB700 Specs
SPEED: 0.09 sec/60 0.075 sec/60 at 7.4V
TORQUE: 583.3 ozf/in (42.0 kgf/cm) 680.5 ozf/in (49.0 kgf/cm)
RATED VOLTAGE: DC 6.0V-7.4V
OPERATING VOLTAGE: DC 4.8-8.4V
Old 04-24-2019, 01:49 PM
  #507
Super Moderator
1/8 IC Fan's Avatar
Stats are cool, but no offense there is a reason the Protek 160t is so great! Its reliable. I have run Futaba since the 80's. B1 is a monster... and who needs 680.5 oz/in? I am trying to pull the tire off the wheel! If i replace my steering servo in my FG TC with the 700 it will perish! That 700 is a cheap shot at Sanwa!!!! Lets be honest... if Futaba came out with a great 1/5 servo it would have been a better day. I would put a 160T against the 700 any day, to outlast it! Remember the servos the OS has been based on have been out for a while!
(I run 1:8 truggy, buggy, 1:8 IC, and 1:5 TC)
  #508
Dan
Dan's Avatar
Trader Rating: 57 (100%+)
The CB700 is a beast of servo. If I were running 1/8th, it'd be my #1 pick.
What is the tech behind this servo that allows it to be incredibly fast/powerful and efficient?
Dan is offline
Old 04-24-2019, 02:05 PM
  #509
Stats are cool, but no offense there is a reason the Protek 160t is so great! Its reliable. I have run Futaba since the 80's. B1 is a monster... and who needs 680.5 oz/in? If i replace my steering servo in my FG TC with the 700 it will perish! That 700 is a cheap shot at Sanwa!!!! Lets be honest... if Futaba came out with a great 1/5 servo it would have been a better day. I would put a 160T against the 700 any day, to outlast it! Remember the servos the OS has been based on have been out for a while!
lol.. stats dont lie.. and who needs that.. if its there.. why not.. lol
Old 04-24-2019, 02:07 PM
  #510
here is a video of the response time of the CB700 vs the S9373
https://www.facebook.com/watch/?v=968112863351349
alot less power draw as well..
