Like Tree55Likes
Futaba 7PX
Old 03-14-2019, 05:42 AM
  #466
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 79 (100%+)
Originally Posted by JRSlash View Post
We have discussed it a bit, but seems not to have its way to the European or North American Soil as of yet. Given now Sanwa is too headed in this direction.
Big Squid release of the ICS-LF-01:
https://www.bigsquidrc.com/futaba-ic...eless-charger/
Futaba USA has nothing on it:
JRSlash likes this.
1/8 IC Fan is offline
Old 03-14-2019, 07:23 AM
  #467
Panther6834's Avatar
While it might be fast, its torque is WAY low. If you're planning on using it to steer a paper airplane, great...but, a car/truck?
EDIT: My bad. Somehow, I accidentally got this posting, and another about a Futaba servo, confused. My excuse - haven't had my morning coffee, yet. Anyway, to this one, seems like a huge waste of money. For far, FAR less money, you can get 2 LiFe batteries...plus, you can still use the Tx while charging the backup battery. With the wireless charger, the Tx isn't useable while charging.
JRSlash likes this.
Panther6834 is offline
Old 03-14-2019, 07:28 AM
  #468
Super Moderator
1/8 IC Fan's Avatar
I believe you are getting the wrong Link, as this is what pops up, and was inquired about:
Old 03-15-2019, 05:16 AM
  #469
dvaid852456's Avatar
So, out of curiosity I tested a few receivers last night by connecting them up to the SKYRC 6in1 box.
My new 7XC and R334SBS showed as 199Hz (I think the max the SKYRC 6in1 can read is 200Hz unfortunately)
My older 3GR and R603FF and R603FS both showed as 199Hz
My 2 OrangeRx receivers showed as 70Hz and these are supposed to be connected via FASST (C1). No wonder the response time was so visibly slow when I compared them.
I went back and tested the 3GR with the 603FF and there was less of a noticeable difference between the 7XC/T-FHSS SR.
dvaid852456 is offline
Old 03-15-2019, 05:23 AM
  #470
Super Moderator
1/8 IC Fan's Avatar
Did you try these in your cars too by chance to see any difference in performance as well? I imagine perhaps then these receivers are probably best left as alternatives for just running around in the yard vs racing?
Was it the GR400F receiver?
Old 03-15-2019, 05:34 AM
  #471
I have the RFA04C and the R6008HV that I used with my 3GR Tx. I did back to back videos and slowed them down to 1/16th speed. You could clearly see the OrangeRx receivers were much slower. The stick was about 3/4 of the way across before the wheel moved. I think they will definitely be relegated to basher receivers and none of my race cars!
Old 03-15-2019, 08:18 AM
  #472
Roelof's Avatar
200Hz is possible, some older radios were limited to 5.5msec framerate because many servo's in that time could not handle more than 200Hz. And FASST is already some years old.....
Today the limit is set to 333Hz as the T-FHSS-SR mode is using on normal servo's. Sanwa is using 384Hz as the ultimate limit of normal 1.5msec center servo's but can give issues with 333Hz servo's.
dvaid852456 likes this.
Roelof is offline
Old 03-15-2019, 07:03 PM
  #473
Default Wow!
Tonight was the first use of the 7XC and it was brilliant! The car felt transformed in that it felt like it only did exactly what I told it to do. Plus the feel and weight of the transmitter was perfect.
​​​​​​I made some small changes during the evenings racing and by Q3 my Xray X10 was incredible. I used 70:30 on the throttle which gave great feel to the acceleration of the car, I removed the lower adjusting nut to have the shortest sticks possible, and I turned the steering expo down to - 20 which helped calm the twitchyness. The car was so driveable, the best it has ever been, sharp, controllable and consistent.
I love this radio and the fact it is so customisable. You can access any item you like so quickly from the user menu and plethora of buttons. It made dual rate and steering expo so easy to adjust out on track.
I am looking forward to trying SR mode once the new servo arrives.
Old 03-16-2019, 01:51 AM
  #474
Roelof's Avatar
I havn't raced with the 7XC yet but playing with the transmitter already made a smile in how it feels. Even with the car on the table it looks like it has a more directer movement than with my previous T3VCS with a Spektrum HRS TX/RX system. And alo a much better feeling in the hands than the 4GRS
Roelof is offline
Old 03-18-2019, 02:23 AM
  #475
What would happen I’d i turn sr mode on for channel 2. Which is for the esc.
riceball777 is online now
Old 03-18-2019, 02:48 AM
  #476
Super Moderator
1/8 IC Fan's Avatar
I would think nothing would be gained. The esc I believe does not require that input. It is not optimized for anything other than regular input. I inquired with HW about this and Sanwas, they stated they are looking into this, either with firmware or updated models.
Old 03-18-2019, 08:34 AM
  #477
Trader Rating: 33 (100%+)
Originally Posted by riceball777 View Post
What would happen Id i turn sr mode on for channel 2. Which is for the esc.
im trying to remember.. i dont think it will turn on with the electric car.. i cant remember
dgrobe2112 is offline
Old 03-18-2019, 11:12 AM
  #478
Roelof's Avatar
Although SR is new, the technology behind it is not. I also doubt the ESC will work but you will never know if you do not give it a try
Roelof is offline
Old 03-19-2019, 12:40 PM
  #479
Was the 7XC / R334 in SR mode, and/or was your 3GR / R603 in HRS mode?
From memory with HRS the reading should be 303Hz, if that's the case you must be right about the 200Hz limit on the SKYRC box.
Does anyone know what the difference between FASST C1 and C2 mode actually is?
C2 is an updated version with slightly lower latency than C1. I think there might be some hardware differences which is why there hasn't been much cross-compatibility unless the TX has a setting for both to begin with.
A little more here: 4PKS Performance, Mode C1 and Mode C2
uDi_MP7.5 is offline
Old 03-19-2019, 02:40 PM
  #480
Thanks for replying, that was just what I was after. The 7XC was in SR mode but no SR servo. I thought FASST was 303Hz and it was definitely in HRS mode. It does seem the SKYRC box has a 200Hz limit according to the manual.
Thanks for the link about C1/C2 mode. I will check it out.
