Like Tree63Likes
Futaba 7PX
Old 01-06-2019, 09:49 AM
  #406
Default Experts needed: How to mix throttle and steering in this particular way
How do I program the 7PX so that the steering throw is lessened as throttle is increased? I want the steering to be 100% at zero throttle and decrease to 50% at full throttle. \
Thanks!
e
enzo thecat is offline
Old 01-17-2019, 01:32 AM
  #407
beyondthepack's Avatar
Has anyone tried to run a R603FS receiver?
beyondthepack is offline
Old 01-18-2019, 10:05 AM
  #408
I have a 4px is it worth up dating to the 7
Emery1 is offline
Old 01-18-2019, 01:39 PM
  #409
Dan
Dan's Avatar
Trader Rating: 57 (100%+)
If you intend to go with the full SR mode everything (receiver and servo), it might be worth it.
If you're not, no need to upgrade. I did not notice much of a difference in non-SR protocol going from 4PX to 7PX.
Dan is offline
Old 01-18-2019, 01:45 PM
  #410
Dan
Dan's Avatar
Does anyone know what "updating" the receiver does? I updated my transmitter to the latest firmware already.
Dan is offline
Old 01-18-2019, 05:41 PM
  #411
MidwestRacer's Avatar
I use my 7PX for carpet onroad racing. I currently have older firmware. My question is, will I notice any performance difference if I update firmware? Also, will I have to re set up model memories and settings if I do update. Thanks
MidwestRacer is offline
Old 01-18-2019, 07:18 PM
  #412
boner's Avatar
Dan: updating the RX to software v3.0 will mostly allow you to wirelessly adjust Futaba MCR970 esc. V2.0 gave you ability to wireless adjust sbus servo setting.
Midwestracer: I don't think there is a performance update on the newer software. you wont lost any of the model setting during/after updates. latest software bring 7px to the same revision of 7px limited - it add ability to control miniz t-fhss rx.
boner is offline
Old 01-19-2019, 10:45 AM
  #413
Emery1 is offline
Old 01-19-2019, 12:09 PM
  #414
Roelof's Avatar
Is there a serious racer using the MCR970 esc?
Roelof is online now
Old 01-19-2019, 01:26 PM
  #415
boner's Avatar
futaba ESC sponsored driver? I think it's more popular in Asian region market.
boner is offline
Old 01-19-2019, 02:33 PM
  #416
Roelof's Avatar
I was wondering what normal used ESC's could work with the SR mode. I was told that the new RPM limiting Muchmore ESC used on the ETS can work with Sanwa its SSR mode so I asume that it can work with Futaba's SR mode as wel.
In the same case I was looking for other brands servo's. I know the SR mode is useng a 720usec servo's but need 800Hz while most 720usec heli tail servo's are limited to 500Hz.
Old 01-26-2019, 08:03 PM
  #417
Trader Rating: 24 (100%+)
How do you get the telemetry off of the radio and on to a pc? I have the converter software, but there is no data on the sd card I have in the radio.
trilerian is offline
Old 01-29-2019, 05:08 PM
  #418
Super Moderator
nexxus's Avatar
Trader Rating: 312 (100%+)
I tried SR mode but ended up going back to std T-FHSS what you gain in speed isn't worth what you lose in Telemetry functions (I use a GPS sensor a lot)
Still can't find out how to log telemetry to an SD card, the card is in the radio and the radio sees it but no idea how to get it to log to it, Futaba Australia don't know either lol
nexxus is offline
Old 01-30-2019, 08:11 AM
  #419
Yeah, I sent an email to Futaba USA and they haven't replied yet... But, after going through the manual again I saw that you have to tie the data logging to a switch to turn it on and start recording. I will be trying this out tonight.
Old 01-30-2019, 08:46 AM
  #420
I just verified that this works. Goto the Switch select sub menu, then choose the switch you want to assign the telemetry to, find telemetry in the selection. Turn the switch on and it starts recording data to the futaba\log folder on the sdcard.
