Looking for upgrade
Hi everyone!
Im wondering about upgrading my b44 brushless combo to a better one. As a noob my local shop sold me a Leopard 12T 3300KV with 60A ESC. Now, I want to upgrade it but i dont want to spend so much on it. Ive been looking and i found turnigy and hobbywing as good/cheap esc(preferable hobbywing). This is what i found: Trackstar gen 2 120a 65€ Trackstar turbo 120a v2 70€ Hobbywing ezrun max10 sct 120a 79€ The last one from HW is a sensorless esc. Then ill be using turnigy trackstar motor i think, something around 6,5T as ill be running on-road. Trackstar 6.5T 5485KV 30€ Trackstar 6.5T 4776KV V2 44€ I have a 4200mah 35c 2s lipos(saddle pack) and 19/81 gearing. Should I go for that 120a esc and 6.5T motor? Wanted to put links and b44 gering rates but theres no way to post a link. Any advice would be appreciated. Thanks :smile: |
Found this Speed passion combo too on ebay
Speed passion reventon pro 140a + speed passion competition v3 6.5T 120€ |
Originally Posted by lexusbest
(Post 14906660)
Speed passion reventon pro 140a + speed passion competition v3 6.5T 120€ I do like Hobbywing a lot as well but I wouldn't get the EZrun combos for racing. I would spend the extra money for the xerun versions. |
2 Attachment(s)
Originally Posted by EbbTide
(Post 14906678)
Out of all those combos, the speed passion would be my choice. I've used their motors and ESC's in the past and they were solid.
I do like Hobbywing a lot as well but I wouldn't get the EZrun combos for racing. I would spend the extra money for the xerun versions. I found this comment over the site, "The B44 has an internal gear ratio of 2.5:1, so with your 13.5 brushless the manufacturers say you should be running a Final Drive Ratio (FDR) of around 7. If you run the 84t spur then you should use the 30t pinion, maybe down to a 28 if the temps are too high (84/30*2.5=7 FDR). Both my brother and myself have just started with 13.5 LRP/Novak Brushless Systems on offroaders and we found we had to gear a little lower. Factory reccomends 7, but we have been at 7.4 or 7.6. That would mean your 84/28 or 84/27 might be the best option." Should i be gearing 27T pinion for optimal performance or is that first image recommended by electronic manufacturer and not team associated? |
(Post 14906732)
Many thanks for your answer. What about gearing?
I found this comment over the site, "The B44 has an internal gear ratio of 2.5:1, so with your 13.5 brushless the manufacturers say you should be running a Final Drive Ratio (FDR) of around 7. If you run the 84t spur then you should use the 30t pinion, maybe down to a 28 if the temps are too high (84/30*2.5=7 FDR). Both my brother and myself have just started with 13.5 LRP/Novak Brushless Systems on offroaders and we found we had to gear a little lower. Factory reccomends 7, but we have been at 7.4 or 7.6. That would mean your 84/28 or 84/27 might be the best option." Should i be gearing 27T pinion for optimal performance or is that first image recommended by electronic manufacturer and not team associated? But as far |
| All times are GMT -7. It is currently 04:53 AM. |
