Like Tree4Likes
Sanwa M12S-RS
Old 05-21-2018, 01:10 PM
  #31
wkloppen's Avatar
M12 Curve calculator. Change the curve(b) value to anything between 0 (very curvy) and 100 (lineair) to calculate the 9 point percentages values. The option is in the Racing Menu. Go to curve and set the type to CRV. Then fill out the 9 point values from the sheet which results in the exact same mathematical parabole as in the sheet. Its not going to win you races but at least you know the values represent the perfect parabole.
https://docs.google.com/spreadsheets...it?usp=sharing
wkloppen is offline
Old 03-06-2019, 12:17 AM
  #32
1evo RRR Driver's Avatar
Fellas anyone in here replace their wheel on a M12S-RS with a after market one? If so , would you be willing to sale me the stock wheel if your not using it............ thanks PayPal ready
1evo RRR Driver is offline
Old 03-15-2019, 10:03 PM
  #33
Lightbulb M12s-RS Telemetry issue
I am using Sanwa M12s-RS with RX482, and Reedy 510R ESC, all working fine; however I am not getting any telemetry data. Did I set them wrong? Please help!
fs968 is offline
Old 03-15-2019, 10:37 PM
  #34
The 510r doesn't send any data back to the receiver. You either need to buy the additional sanwa sensors, or use a sanwa ESC to get the telemetry data.
big ted is offline
Old 03-16-2019, 05:42 PM
  #35
Thx big ted, do u know the Sanwa sensor part number?
fs968 is offline
Old 03-16-2019, 07:44 PM
  #36
i could be wrong but i dont think the 482 will allow for a sensor.
Bry195 is offline
Old 03-18-2019, 07:28 AM
  #37
Rx 482 should be telemetry capable. Telemetry sensors for temperature & rpm are at the bottom of this page:
http://sanwa-denshi.com/rc/car/option1/
big ted is offline
Old 03-18-2019, 07:58 PM
  #38
It is telemetry capable (I use it) but you have to use a sanwa esc and sanwa servo. There are no ports for external sensors. For motor temp on a sanwa esc you need to confirm that the temp sensor is embedded in the motor and comes across the ribbon cable. Some motors have it some dont. A reedy splus did not have it so I added a 10k ntc thermistor to the ribbon cable and attached it to the can. i have a monster max that has the embedded sensor so not hodge podge required. If you dont need servo telemetry then you dont need a sanwa servo.
By the way. It has to be one of the greatest things ever to always know motor temp and have automatic handling of over temp. I can adjust timing in tiny increments based on the track and ambient. No sensors required. Once I work out the exact timing through the m12 electronically I can just take it all out of the transmitter and adjust it into the end bell.
uDi_MP7.5 likes this.
Bry195 is offline
Old 03-19-2019, 12:21 PM
  #39
Bry195 is correct, the RX482 isn't compatible with those temperature and rpm sensors.
For future reference, neither are RX481, RX472, RX471.
Does anyone know of any good / cheap aftermarket receivers that support the FH4T SHR / SSR response and have at least one temp sensor input?
Or are RX461 / 462 the only options?
I agree it's amazing to have live temperature data and management, it's a shame Sanwa doesn't make a 1/8 speed control to allow every class this benefit without the external sensor clutter and cost of getting a new RX.
Bry195 likes this.
uDi_MP7.5 is offline
Old 03-19-2019, 12:45 PM
  #40
Interesting. I stand corrected.
big ted is offline
Old 03-20-2019, 07:55 PM
  #41
I know nothing about 1/8 but the sv pro blah blah blah is ludicrous current. If i would have known i only needed 90 amps peak in 17.5 touring I wouldn’t have bought all those pro blah blah blahs. I think they are rated to like 400 amps. I can confirm the sport versions (cheap) can handle a 17.5 touring car at 90 amps peak without losing an amp.
Bry195 is offline
Old 03-20-2019, 08:01 PM
  #42
By the way you can add any sensor...temp, rpm, ....if its resistance is in the range of a 10k ntc thermistor by patching it into the brushless ribbon cable.
Bry195 is offline
