Tekin rx8 gen2 problem
So i just hooked up my brand new system and when i turned it on i get red scrolling lights. It says on the tekin site that it could be the fan polarity reversed but i unpluged it and put it the other way but its still happening? Did i fry the system.......
Is it plugged into a bound RX? You may want to ask this in the RX8 Gen 2 thread. http://www.rctech.net/forum/radio-el...hread-243.html
yea nvm i got it post can be deleted
Originally Posted by Derrick87
(Post 14898103)
Gotta calibrate it to the radio
The "Night Rider" code is the fan being plugged in backwards. The radio calibration wasn't the issue UNLESS there were 3 LEd's to one side.
So i set the fan on the esc to auto and it says it should kick on at 140F but today i took the buggy out and it was only about 60 outside and i would only go about 2 times around the track and the fan would kick on and keep running i temped everything and the hotest everything got was 80f any ideas.....
(Post 14899136)
Originally Posted by EbbTide
(Post 14899143)
Did you just use a temp gun or did you also use the LED lights on the ESC to check temp?
(Post 14899161)
I just used a temp gun how do i use the lights on the esc i didint know you could do that.
In short it blinks a certain LED to show the temp. The manual shows what each LED adds up to in Fahrenheit |
is there a reason for the fan to be kicking on like that or is something wrong?
(Post 14899174)
(Post 14899185)
Well that's why I was asking if you checked the onboard temp because perhaps the ESC was misreading it's temperature. So the temp gun says one thing but the ESC might say another.
(Post 14899200)
Ill have to check it next time i get to the track and see
So yea 2 times around a short course track and its hitting the 120f mark on the esc......
| All times are GMT -7. It is currently 12:19 AM. |
