iCharger Replacement Suggestion
My iCharger 308 just went busto and will head into a lengthy RMA process so I'm getting ready to buy a new charger and then sell the 308 after.
Even thou a lot of people have great experiences with iChargers, I have had some bad luck. The first one arrived DoA and the second one I'm on now has it's screen busted - so I'm looking for alternatives. My budget is $250 max. What I charge: - 2S 4000-5000mah - 3S 4500-5500mah - 4S 5500-7500mah I have very little idea about chargers so I look forward to your suggestions! |
Are you looking for an AC/DC charger or just DC?
Same issue here... So I went fishing and found these. I really like the Ev-Peak A8
EV-PEAK 45a charge finishes an 8k 2s stick in 12 minutes |
Originally Posted by Xpress..
(Post 14885637)
Originally Posted by hanulec
(Post 14885656)
EV-PEAK 45a charge finishes an 8k 2s stick in 12 minutes The specs read very well but I can't find much info/experiences on them. I've been looking at the Orion Touch Advantage AC/DC...a lot less charge power but seems pretty nice to take to the track with you. |
I just order the new ProTek RC "Prodigy 625 DUO Touch AC"
https://www.amainhobbies.com/protek-...k-8519/p578442 |
I just came across this: HT206 20 Amp - 200 Watt AC/DC Dual Charger
looks pretty sick for the money...and given that its SMC carries it, I'd expect some quality |
Reedy Charger
I went and ordered the HT206 - will report back
Me personally, after using the 308 Duo, couldnt think of any other charge that could come close in the performance and/or features.
I agree with you but after one channel on my charger went up in smoke,the other channel not working properly and a shipping cost over a hundred dollars to have it repaired I'm looking for another charger too.
Originally Posted by disaster999
(Post 14885932)
Originally Posted by outlandr91
(Post 14886476)
Originally Posted by Andy Koback
(Post 14886485)
And...unless you purchase them thru Progressive, no one else will repair them either.
Originally Posted by mlax
(Post 14885928)
(Post 14887992)
Purchasing through Tower Hobbies is fine as well. Progressive handles CS for them.
| All times are GMT -7. It is currently 06:58 AM. |
