Lipo Battery Question
I have a lipo battery that when I try to charge it I get a low voltage error. Does that mean the battery is no good.
Originally Posted by endy0430
(Post 14875769)
No I bought the battery from somebody. I can get a voltage checker what do I do?
Thanks |
sometimes when this happens you can charge the battery in nimh mode to bring the voltage up to correct charging specs, then switch to lipo mode to charge the battery as normal.
(Post 14875805)
Thanks The only other way you might get that same charge error is if you forgot to connect the balance plug as well as the charge plug. |
| All times are GMT -7. It is currently 11:34 AM. |
