Tekin Rx8 Gen3....interesting >
Like Tree51Likes
Old 10-26-2018, 11:48 AM
  #226
Team Tekin
Randy_Pike's Avatar
Originally Posted by UK.hardcore View Post
Do 10 AWG wires fit in gen 3 solder posts?
They can but they're NOT required. 12 awg is MORE than enough.
UK.hardcore likes this.
Randy_Pike is offline
Old 11-02-2018, 06:36 PM
  #227
Lineman26's Avatar
So over the last few weeks I've put two new RX8 Gen 3's in my new Tekno's, one ET48.3 and one SCT410.3, plus a RX4 in my crawler. The ET has the Gen3 T8 2250kv truggy motor and the SCT has the T8 2650kv buggy motor. Crawler has the ROC 412hd 1800kv. My question is what actual difference should I notice by adjusting the frequency settings through hotwire? When I compare 2000 to 12000 the only thing I really notice on either vehicle is the motor makes much more noise on the 2000 setting. That's about all I notice. What does it actually do?
Lineman26 is offline
Old 11-07-2018, 11:19 AM
  #228
Team Tekin
Randy_Pike's Avatar
Lower frequency gives more punch, higher frequency is more smooth.
You're running a 2650 in a SCT? On what battery? That's a HUGE motor for the class.
Old 01-11-2019, 07:49 PM
  #229
I've got my Gen 3 RX8 in my SCT with a pro4 4300. In my buggy I'm running a HW 1900 with a HW Xerun XR8 SCT Pro. Thinking of swapping these two ESC's around as the RX8 seems better suited to 1/8. Aside from all the tuning options of the RX8, do you think this would be worth the effort.
TxLoser is offline
Old 01-13-2019, 10:07 PM
  #230
Team Tekin
Randy_Pike's Avatar
I see no harm in swapping them around.
Old 01-17-2019, 09:05 AM
  #231
savage24x's Avatar
Can the 30x30x7 fans take 7.4v? They're the only fans I can find in that slim profile. I have one connected directly to my receiver which is getting 7.4v from my ESC.
Fan in question: https://www.teamtekin.com/shop/index...product_id=118
savage24x is offline
Old 01-17-2019, 10:34 AM
  #232
Team Tekin
Randy_Pike's Avatar
Yup, they can.
savage24x likes this.
Old 01-18-2019, 07:54 AM
  #233
Could someone list the exact differences between the Gen2 and Gen3 T8 motor for me?
I'm asking about both buggy and truggy versions.
I couldn't find much on the website about it, a comparison table would be really handy as many sources still sell both versions brand new.
The same for the RX8 G2/G3 could be useful too although I'm just looking at the motors right now.
Thanks for any help
uDi_MP7.5 is offline
Old 01-18-2019, 01:51 PM
  #234
Team Tekin
Randy_Pike's Avatar
Thanks for any help
The motors are very close. You can't go wrong either way. The updates however are stronger rotor, new stack features and lower resistance.
The Gen2 Rx8 hasn't been produced in awhile, get the Gen3 and get the current stuff.
Old 01-19-2019, 08:28 AM
  #235
Thanks Randy, is the old rotor prone to any problems, or should it still last a long time provided temps are monitored/managed?
When replacing the rotor can you use the G3 on G2 motor, or not the case?
I also am unsure what stack features are. Appreciate your help. I will aim for the G3, but good to know either way.
Another question - I noticed only the 1700kV and lower are rated for 5S, is it possible to run 1900kV on 5S provided gearing is lowered appropriately?
Or is there some limitation other than max temperature?
Old 01-19-2019, 05:19 PM
  #236
Team Tekin
Randy_Pike's Avatar
The "old" rotor was fine also. The later Gen2 motors received the Gen3 rotor as a running change. Both are swap able between the two. The stack feature while an improvement is not something 99.9% of the drivers will notice on the track so much. The efficiency is where gains are made.
You can run a 1900 on 5s, just assure you're changing the gearing, etc.
