-   -   I charger and parallel charging (https://www.rctech.net/forum/radio-electronics/980989-i-charger-parallel-charging.html)
brandon32689 03-09-2017 05:27 AM
Hey guys, I been thinking about getting a I charger. Is it worth it for you basic racer. I really do not have a ton of batteries. But I was also curious on charging parallel. For instance if I have 5 4s lipos. What is all required and is it better to just charge 1 at a time. Thanks
jk6672 03-11-2017 09:44 AM
I parallel charge all the time, but it's a habit I picked up from flying 12s setups flying.
You need a good parallel board or two. I have quite a few, but I use this one for my surface packs. you can get a quality parallel board from
progressiveRC.com
https://c2.staticflickr.com/4/3735/3...e75f0396_z.jpg
Here's my charger:
https://c2.staticflickr.com/4/3823/3...0f62f7ae_z.jpg
it's mounted on top of a 2000w means power supply.
https://c2.staticflickr.com/4/3838/3...69aaee11_z.jpg
brandon32689 03-11-2017 09:55 PM
progressiveRC.com
Here's my charger:
That is awesome i just got the Icharger 406 duo i will pick up a parallel board as well. I like that case yours is in i want to build something similar.
