Regenerative discharge ??? >
Old 02-21-2017, 12:00 AM
Trader Rating: 32 (100%+)
Default Regenerative discharge ???
Some chargers use this term for their discharge function (esp icharger).
What is this??? & how does it works???
Also what is the difference between normal discharge & regenerative discharge??
hobbs is offline
Old 02-21-2017, 06:26 AM
Instead of using the internal resistor to discharge it passes the current through the other channel on the charger into another battery, or car battery, or a resistor bank like this 40amp Resistor Bank for Icharger.
anr211 is offline
Old 02-21-2017, 07:34 AM
So, this regenerative discharge only works in a charger with duo charging ports??
hobbs is offline
Old 02-21-2017, 10:56 AM
I don't know how it would work any other way. The current has to go somewhere else to be regenerative. If you're just looking for high current discharge the cheapest option would be the integy reactor 30.
anr211 is offline
Old 02-21-2017, 11:16 AM
Trader Rating: 23 (100%+)
it can work with the single port ichargers too. read the instructions
Coke in a can is offline
Old 02-21-2017, 11:17 AM
Trader Rating: 46 (100%+)
No, single port iChargers can use this (and DUO models as well) by using a power supply source that will accept a charge, AKA a battery: http://www.icharger.co.nz/manuals/308DUO.pdf - page 38. Single port models can use a resistor to boost discharge capacity with discharge + setting: https://www.progressiverc.com/media/...B%20Manual.pdf - page 18.
biz77 is online now
Old 02-21-2017, 02:54 PM
dtr
dtr's Avatar
The main difference is that with normal discharge you waste the energy as heat on a resistor, it works with any power source. Regenerative discharge puts the discharged energy back into the power source, so it only works when the charger is powered from a battery.
dtr is offline
