-   -   Competition electronics turbo dyno (https://www.rctech.net/forum/radio-electronics/979017-competition-electronics-turbo-dyno.html)
eazy70 02-20-2017 05:37 PM
I have a turbo dyno, and the slave motor is wearing out. I located and bought some brushed 24t and 27t motors, I tried them, but for some reason the torque numbers are alot higher than what I am trying to test.
Can anyone tell me what brushed motors that I should be looking for, or if anyone has any for sale.
Thanks.
eazy70 02-22-2017 04:43 AM
Anyone?
Andy Koback 02-22-2017 08:12 AM
Seems to me the slave motor was like a 55T motor.
Kraig 02-22-2017 08:38 AM
The manual says 24 turn.
eazy70 02-22-2017 09:03 AM
I know but I tried a couple of them, and the torque numbers are way off.
I will try again.
Andy Koback 02-22-2017 11:18 AM
Here's a download to the manual. May be of some help to you.
http://www.competitionelectronics.co.../TURBODYNO.pdf
ta_man 02-23-2017 02:47 PM
One thing that is important with the Slave motor on a Turbo Dyno is that it must be set to zero timing. Most 27T motors are fixed timing and since you are running the slave off the test motor it is running backwards which is not really good for it.
The best thing you can do is to try to find a large com Yokomo armature and use it in a can that has stand-up brushes. Set the motor to zero timing using a mod motor (adjustable timing) can.
If you can't find a mod Yokomo arm of the correct turn rating, you next best thing is to find one of those Reedy 19T quad mag motors. Like this: Reedy Pro 19T Quad Mag Brushed R/C Racing Motor #516 NIP NR BIN | #431622122
Then use that arm in a Trinity/EPIC, etc. mod motor can with stand-up brushes. Those reedy motors had the large comms. The benefit of this is that the slave motor lasts a lot longer before needing to be rebuilt because the large comm and narrow brushes eliminiates the brush overlap that causes arcing. You don't want to use that motor as-is because it has laydown brushes.
There are places that still do custom hand winding of brushed armatures (Holmes Hobbies comes to mind) but you really want a large comm blank if at all possible. And Zero timing.
eazy70 02-23-2017 04:26 PM
Ok this makes sense, I know its the timing that is screwing me up.
Thanks again.
JFuel11 12-22-2017 08:46 PM
Looking to purchase a TurboDyno if anyone has one for sale.
