Spektrum DX5R
#76
Lanyard mod
Okay so this is a nice radio but it's missing a lanyard. So I decided to make one of my own. Initially I have the lanyard wrapped around the base like everyone else however, I figure there's got to be a better way so I ordered this threaded camera connecting adapter and added it to the remote. Initially I was going to put it on the backside of the remote where there is a round grommet plug. However, I'm right handed and the lanyard would be in my way while driving. So I then decided to put it on the base right side of the handle as in the picture. I would have to drill a hole and attach a nut to the under side. As I was about to take the transmitter apart I noticed that one of the screw holes matches the size of the threads on the connector so I Simply Shredded it into the plastic and voila a solidly affixed lanyard connector. With no drilling required. Got to love it. Hope you guys enjoy the mod.
The connector
The side placement option
The screw hole
the connector installed
The lanyard attached and ready to go
The connector
The screw hole
#77
The connector
Attachment 1428368
Attachment 1428369
The screw hole
Attachment 1428370
Attachment 1428371
Attachment 1428372
The connector
Attachment 1428368
Attachment 1428369
The screw hole
Attachment 1428370
Attachment 1428371
Attachment 1428372
#78
Here is a ebay link but if you do a search for:
1-4-034-Screw-Connecting-Adapter-Alloy-for-Camera-SLR-DSLR-Camcorder-Quick-Strap 1-4-034-Screw-Connecting-Adapter-Alloy-for-Camera-SLR-DSLR-Camcorder-Quick-Strap 1-4-034-Screw-Connecting-Adapter-Alloy-for-Camera-SLR-DSLR-Camcorder-Quick-Strap 1-4-034-Screw-Connecting-Adapter-Alloy-for-Camera-SLR-DSLR-Camcorder-Quick-Strap Have one to sell? Sell now Details about 1/4" Screw Connecting Adapter Alloy for Camera SLR DSLR Camcorder Quick Strap
It should bring up several options. Cheap and easy way to add a lanyard.
#79
DX5R is some what a disappointment
Had it about a month. DX4R profiles are incompatible. had to redo the important ones by hand. Im using the ion battery also.
So last weekend im at the r aces and enter 4 class (normal MO for me) and decided to recharge battery between heat 1 and 2. got up on the stand and powered up radio, well all most powered up. it display a "RAW INPUT SCREEN".
couldnt get by it no matter what. Monday called spektrum and they said please send it back for a reset. What? there is no firmware update yet on the website. Looked around an see the dx6 aircraft radio has similar issues.
Wonder whats up?? Will it happen again? Ran the DX4R for several years without any issue like this.
#80
"The radio needs a hardware change to support that battery pack. You'll need to send it in for it to become compatible. As shipped, it only supports NiMH and Alkaline."
Uh... no. As previously mentioned by other posters, once the voltage drops to low 8s or 7s, it will turn off without vibrating.
Support also suggested to run the update which I did via SD card even though it was the same version, so I no longer get the "registration" screen when I turn it off.
#81
Just updating regarding using the SPMB2000LITX LiIon battery with my DX5R. Reply from support:
FWIW, my radio has options for Nimh, Alkaline, LiIon, and Lipo, and has never been sent back. Perhaps it's already a running change in production.
#82
Nope, despite having menu options for all 4 battery types, my remote vibrates continuously when you power it down if the SPMB2000LITX LiIon battery is over 8V.
I'm having trouble running the 1.00 update to get rid of the registration nag screen. I used the same micro SD card to update the firmware on my back-up DX4R Pro which worked fine. I've tried reformatting it and even tired a different file system with no luck. The radio just turns on like normal despite the SD card being inserted with only the back-up file on it, in the root directory. If I go into the System setup screen, the radio acknowledges there's an SD card inserted in one of those menus so I know it "sees" the card. Frustrating.
Aside from those two issues, I like the DX5R much better than the DX6R I just sold. The Android platform just added a whole lot of instability and battery drain. The basic monochrome screen is much more akin to the reliable DX4R I'm replacing. Now that I swapped over the large grip and a wheel wedge from the 6R, it's setup perfectly.
Now to do something about this battery door...
#83
#85
Do any of the "orange" receivers work with the DX5R or any other after market ones work?
#86
My battery mod was creating a Y connector to go along with my LiIon battery with an inline switch from a busted Novak ESC where the standard opening in the battery door is. I also added another opening to pull out the connector to charge the battery. I just cover the opening with electrical tape (and over the switch so it doesn't turn off if when I set it down). The switch is for disconnecting the battery from the transmitter when not in use or charging the battery. It functions well even though it's not that aesthetically pleasing. It would also help turn off the transmitter if it was still havng the vibration issue.
#87
Where do you get these orange SR3100 receivers?
#88
#89
Fix for "raw input screen is firmware version 1.1.03.
went through upgrade firmware procedure per manual and completed raw input testing.
Next popped up at bottom and completing the additional question took me to the normal power up screen, YES!!
#90
Spektrum™ DX5R RaceWare™ 2017- June - 21
Change Log Version 1.01.03
New Features
Model Import/Export - Users are now able to share model setting via the micro SD Card and Transfer SD Card menu.
Language Support- German, Spanish and Italian have been added to System Setup menu. Previously only English and French were supported.
Alarm Options- Options for the low battery and inactivity alarms that include Inhibit, Tone, Vibe, Tone and Vibe have been added
Improvements
In the Systems Settings menu, the scroll function is more intuitively and predictably. Drive Modes are now properly added and removed
Trim box options at the bottom of the main screen are more accurately displayed
MOA switch assignment is now unassigned when MOA is inhibited
AWS Screen allows the option to set the Switch setting back to INH
Drive Mode 1 allows a rate change to be made when Drive Modes are enabled
AVC switch options now include Inhibit, drive mode and switch I
Steering Override and OTF is now available on the Steering channel under the Rates Menu
Switch position set to Toggle a channel now appropriately drives the output channel
On the MOA screen the switch position indicator is no longer displayed when MOA is inhibited
Switching between Drive Modes now emits a tone to indicate change
Drive Mode Names are now being properly displayed on the main screen
Drive Modes are properly changed using the three position switch
Drive Mode # is properly shown on the Main Screen
In the Traction screen, trimmer direction in no longer visible when Traction is inhibited Exiting the Model Select screen is now easily done with the BACK button
New Features
Improvements
