Like Tree13Likes
Spektrum DX5R
Old 04-08-2019, 09:54 AM
  #316
nikos2002's Avatar
Trader Rating: 29 (100%+)
Originally Posted by proliteandsc View Post
I have a TT-02 car with a brushed TBLE02 ESC that went up in smoke. LHS told me it could be the AVC control on the srs4210 reciver. I wasn't using the AVC when this happened. Is that AVC system meant work with a brushed motor ? If I leave the bind plug into the disable port during operations. It should disable all AVC functions, right?
From the Manual - If you participate in organized racing, you may be required to turn AVC
technology off. To turn off AVC technology, insert a second Bind Plug in the
Disable port before binding.
You can take both bind plugs out after the bind process. AVC and its functions (or not functioning) would not cause an esc to burn out. Don't really know why the HS would immediately blame AVC.
nikos2002 is offline
Old 04-10-2019, 06:33 AM
  #317
Update, the fix on the hardware for the radio is well worth it. I have been running the LiIon battery now for 3 weeks no charge, no voltage drop.
Thank you Nikos in suggesting to send the radio for the fix.
Mahjik likes this.
sebtarta is offline
Old 05-28-2019, 11:21 AM
  #318
Trader Rating: 36 (97%+)
I sent my radio in for the update and the LiIon battery(spektrum spmb2000LITX) still drains. All they said on return of the radio was software update done and I could do this on my own next time, so was that all the update for the battery was
? Also how do you guys charge these packs?
Savage03 is offline
Old 05-28-2019, 11:26 AM
  #319
They did not do it then. They need to change a diode inside which fixes the battery drain. I would definitely call back and let them know about it. Maybe Nikos can help out as well?
As for charging i use my charger, setit to LiIon at 2000mah and have it charge.
sebtarta is offline
Old 05-28-2019, 11:56 AM
  #320
My charger doesn't have a LiIon .
Sucks if they didn't cause means shipping it back again and waiting.
Savage03 is offline
Old 05-29-2019, 04:48 PM
  #321
Got ahold of horizon and he confirms the guy didn't fix the lipo issue just did a firmware update. Is being nice enough to send a shipping label on their dime.
Is their another way to charge a LiIon?
Savage03 is offline
Old 05-30-2019, 10:45 AM
  #322
That is good that Horizon at least is fixing the issue once in for all. Only drawback is being without a radio for another week.
As for charging a LiIon you need a charger that can charge LiIon, no other way around that I know of.
sebtarta is offline
Old 05-30-2019, 10:58 AM
  #323
nikos2002's Avatar
Savage, sorry to hear there was a miscommunication about the battery upgrade. Can see where it might get a little confusing on both sides when you compare and update/upgrade. As mentioned above, to use the LiIon, you a charger designed to work with that chemistry
Old 05-30-2019, 11:49 AM
  #324
Well only thing is when I filled out the form I specifically said I needed the update to fix the lipo draining issue. I person that emailed me back even said so and for what ever reason the tech did something else. Sucks bought the battery cause I don't have a charger for a LiIon, see if I can find a lipo to fit. Thanks!
Savage03 is offline
Old 06-12-2019, 09:48 AM
  #325
Kepner's Avatar
How do I make this "knob" do something? I was gonna try and use it as a adjustable exponential steering rate knob or something else. Or just make it so I can adjust random things easier during the initial setup of the car.
Kepner is offline
