Icharger 4010 question
Just to confirm, in order to discharge at 40 amps, this charger requires an external resistor bank right?
That's correct.
Maximum Discharge Power Capacity: 200W (Channel 130W) Watts = Volts * Amps 130W = 8.4V * ~15.5A You'll only get approximately 15A discharge at 2S using just the charger in single-channel mode. |
Ok thanks!!
Good info.
| All times are GMT -7. It is currently 02:20 PM. |
