-   -   M12 throttle neutral position offset (https://www.rctech.net/forum/radio-electronics/973465-m12-throttle-neutral-position-offset.html)
nismoflip 01-06-2017 10:47 AM
I purchased a used M12 and I can't figure out why the Ch 2 throttle neutral position is offset. I'm having difficulty calibrating my Castle ESC neutral position and I think it is because of the tx nuetral throttle position. Trims are centered, subtrims at 0, and EPAs at 100%. Please advise. Here are some pics:
http://i134.photobucket.com/albums/q...psrboslcdk.jpg
http://i134.photobucket.com/albums/q...pszreqnets.jpg
mikeygar 01-06-2017 11:06 AM
check your trigger setup if it is set at 50/50 or 70/30. Some ESCs won't calibrate with 70/30 so set it to 50/50 then try again
stuntstein 01-06-2017 11:27 AM
Check sub trim.
Also try calibrate your transmitter.
nismoflip 01-06-2017 01:05 PM
Guys thanks for the tips. The final fix was even more bone headed than I thought it was going to be. I didn't have the ESC lead in the throttle slot on the RX. Doh
Keith B 01-06-2017 01:26 PM
Got you, the throttle lead goes in after the servo lead.:lol:
nismoflip 01-06-2017 01:40 PM
I'm a moron. I've been in the hobby for 25 years and still missing things lol
