-   -   Brushless motor rotor Shims? (https://www.rctech.net/forum/radio-electronics/973449-brushless-motor-rotor-shims.html)
madmat_tco 01-06-2017 09:11 AM
Is there a specific king of shims I should be using to shim the rotor? Can I use the same shims as I'd use for other stuff like diffs or bearings?
1/8 IC Fan 01-06-2017 09:28 AM
Motive has a nice kit:
http://motivrc.com/store/#!/MOTOR-SH...egory=13438641
The others are probably a different size, I do not know any other use of such a small bearing RC Wise (other than perhaps a micro RC) that would use such a shim. Maybe also for TC Hinge Pins. But best off to use a kit as designed for motors.
