So is a 4th channel necessary?
4pv or pls? |
Originally Posted by Fbodykiller
(Post 14791419)
4pv or pls? |
Originally Posted by EbbTide
(Post 14791425)
For electric rc cars a 4th channel is totally optional. With a 3ch RX you can power your ESC, Servo and an extra cooling fan for the motor or run a transponder. Although I believe a motor fan and a transponder can just use the same 3rd channel with a splitter cable.
(Post 14791419)
4pv or pls?
The 3PV is great and has all the basic features that you could need, but lacks some more high-level adjustments such as servo return speed, has no timer function, no adjustability of the trigger or wheel position or tension. It is light and reasonably tough with a more basic menu system. The 4PLS has all those extra features but is an older radio. The exposed folding antenna is a definite downside. Being able to adjust the trigger position, brake stop, trigger and steering tension is a big plus. The 4PV is the newest Furaba radio and seems the best of both worlds- the newer replacement for the 4PLS. Whatever you get, look for the packages that come with the 'e' variant receivers if you'd like to do without antennas on the receiver. |
| All times are GMT -7. It is currently 08:06 AM. |
