QTECH Power Terminal Motor Terminals
Has anyone used or using this motor connection system from RSD?
http://www.reflexracing.net/QTEQ-Pow...pe_p_1553.html |
Hmm.... Looks like a dead end on these terminals. I can't even get an answer from RSD about them. Dang sure afraid to try and order some. :confused:
I've used the QTEQ terminals on LRP ESCs. Never used them on my motors. Really like the convenience of not having to solder wires directly to the board when I want to change something around. I know Hobbyking sells something similar that I have used as well. You may want to check there.
Thanks biz77. I'll take a look at Hobbyking.
they are used overseas in the ets spec classes
| All times are GMT -7. It is currently 11:23 AM. |
