Need help
I've set up an LRP Sphere esc. The lights confirm it has been setup correctly, but when I give it throttle, the motor doesn't turn and gets very hot very fast.
My battery is an older Orion 2s 3600 25c carbon edition lipo. The equipment hasn't been used in years, but worked perfectly fine before then. Anyone have an idea(s) what the problems might be? Thanks |
Sounds like the motor may be locked up
Is there a way to unlock the motor? It's a Novak 17.5 and I have 2 of them and both would not work.
If both motors don't work, it might be the ESC.
Originally Posted by rgrg2
(Post 14768489)
I got the motor working. It was a radio setting. But now when I put the vehicle on the ground it started to move and then stopped. Is this a slipper problem or something else? |
| All times are GMT -7. It is currently 04:27 AM. |
