Help with motor analyzer - SkyRC Motor Analyzer >
Like Tree1Likes
  • 1 Post By nexxus
Old 12-14-2016, 04:33 AM
rctazmanmc's Avatar
Trader Rating: 109 (99%+)
Default Help with motor analyzer - SkyRC Motor Analyzer
Hey guys.
Just picked up a SkyRC BMA-01 Brushless Motor Analyzer and need a little guidance on what to look for and check.
Need tips / set-up for on-road 17.5 motors and off-road 17.5 and 13.5 motors - timing, amp draw, shimming etc.
I got lots of experience with brushed and limited with brushless tuning.
Seen videos on YouTube and what they provide but like some experienced racers feedback.
rctazmanmc is offline
Old 12-14-2016, 05:14 AM
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
Watch Nick Adams on youtube lots of good info on setting these motors up using the analyzer.
1/8 IC Fan likes this.
nexxus is offline
Old 12-14-2016, 06:06 AM
rctazmanmc's Avatar
Thanks!
I will check out soon. Rather not burn up a perfectly good motor but I also want to tune to be competitive and have power.
Old 12-20-2016, 05:02 PM
nova2015's Avatar
I've been playing with one of these, and found my Tekin Gen 3 21.5 to have a bit of a variance between phases. When tested at an indicated 30 degrees, Phase A=23deg, B=29 and C=31. Is there a means to get the motor back in sync?
nova2015 is offline
Old 12-23-2016, 07:33 AM
d16dcoe45's Avatar
yes, u physically unsolder the sensors on the sensor board and move them little by little to the correct positions--and of course permanently solder them back. Its a trial and error process but should give you a faster, more consistent motor.
Some of my 5% Trinity motors (D4 1s and 24k) were the WORST offenders, being from 7 to 10 degrees out from a-b-c!
d16dcoe45 is offline
Old 12-27-2016, 02:50 AM
rctazmanmc's Avatar
What amps you guys setting the motor at for off-road stock buggy and truck?
I seen 6.5 amp draw but want to make sure.
Old 02-26-2017, 12:45 AM
JAE
Trader Rating: 30 (100%+)
...delete
JAE is offline
Old 06-17-2019, 05:02 PM
Default Can you use the analyser while motor is attached to ESC
Hi,
do you have to detach the motor from the ESC before you can use the motor analyser? If you can , it saves a lot of time in testing a motor that is currently installed in a car.
Bernard
rbc626 is offline
Old 06-17-2019, 05:11 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 235 (100%+)
Originally Posted by rbc626 View Post
Hi,
Bernard
you can if the esc is not turned on just remove the pinion , but i would still disconnect it from the esc
Marcos.J is offline
