-   -   Voltage on life (https://www.rctech.net/forum/radio-electronics/966753-voltage-life.html)
HB-forever 11-02-2016 02:48 AM
Voltage on life
Hi
Have a question regarding voltage on life rx batteri after it has been charged. It peaks on 7,20v , how good does it hold voltage after? Have a vampire that without any use drops to 6,65 after 10 minutes.
My car lipo holds its voltage of 8,40v for a long time
Grizzbob 11-02-2016 10:34 PM
Well, I have a couple of 6.6V LiFe packs I use in my Tx, & when I charge tham sometimes they have to sit for several days before I'm ready to use one. And when I do, they both read at 6.8V in the transmitter(& peak at 7.3V on the charger). It's the same for both packs, pretty consistent(& they hold up well too, my first one is over 4 1/2 years old, my second one is about 6 months old, & both look & perform the same, I can only tell the difference between them by seeing a couple of visual cues(like a nick on the wires of my older one)....:cool:
GerryH 11-05-2016 07:48 PM
My LIFE batteries for TX last for months all in the 6.6-6.8v range.
You said you're using it as a receiver battery. Could it be your servo(s) draining it?
