Like Tree6Likes
KO PROPO EX-RR
Old 02-25-2017, 02:16 AM
  #61
Hello
Been out of the hobby for a few years (last radio KO Mars! )
Can get a good deal on the EX RR.
Is it a better radio than the EX 1 and robust enough (receivers) for nitro buggy racing.
Many Thanks
Tom
Tomigun is offline
Old 02-25-2017, 02:31 PM
  #62
does this work with the ex rr?
KO Propo 3D Extension Unit For KIY Radio (KOP10501) | eBay
sn47som1 is offline
Old 02-25-2017, 02:33 PM
  #63
Team Tekin
Randy_Pike's Avatar
Originally Posted by sn47som1 View Post
Yes it should.
Randy_Pike is offline
Old 02-25-2017, 02:35 PM
  #64
deleted
sn47som1 is offline
Old 02-25-2017, 02:38 PM
  #65
deleted
sn47som1 is offline
Old 02-25-2017, 04:53 PM
  #66
Originally Posted by Randy_Pike View Post
Yes it should.
should or does? its too pricey to go unsure. what do you think?
You said this in an earlier post and i quote, "The wheel is the same as the Ex-1. I used my same 3d module to drop onto the Ex-RR"
Is this the same 3d unit i posted above?
Also what transmitter bag will fit the ex rr with 3d extension unit?
sn47som1 is offline
Old 02-25-2017, 07:19 PM
  #67
Team Tekin
Randy_Pike's Avatar
Yes, I have successfully used ALL my Ex-1 KIY parts on the new Ex-RR.
I use the KO Propo hardbox.
Old 02-26-2017, 08:42 AM
  #68
savageboy69's Avatar
Trader Rating: 93 (100%+)
they dont make that box anymore right?
savageboy69 is offline
Old 02-27-2017, 09:18 AM
  #69
Team Tekin
Randy_Pike's Avatar
It doesn't look like it.
There's this one: HERE
Old 02-28-2017, 10:12 AM
  #70
on KO site, it's listed as compatible
3D Extension Unit for KIY - KO PROPO -
Martin
rhodopsine is offline
Old 02-28-2017, 05:39 PM
  #71
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
beyondthepack and LOW ET like this.
Rich Panganiban is offline
Old 03-01-2017, 06:28 AM
  #72
beyondthepack's Avatar
I started my research for a replacement for my 4PKSR. I like the feel of the KO, holy hell im confused with all the hardware. First off do I need the 30214 servo in all cars, and what is the extra boards for in this pack
http://www.rcmart.com/propo-ko92391-wgrasper-21010-30214-61029-61031-p-71312.html
A little clarification would help
beyondthepack is offline
Old 03-05-2017, 06:49 PM
  #73
165 bucks for a receiver is harsh
Bubonic-X is offline
Old 03-06-2017, 09:00 AM
  #74
Team Tekin
Randy_Pike's Avatar
KO PROPO RS set w/ BSx3 One 10 Grasper Servo (21010, 30214, 61029, 61031), ,(KO-92391)
You can run whatever servos you'd like. However the RR has the option of changing the tx/rx mode to utilize the Grasper servos which operate a little differently than a regular servo. They're always moving trying to improve their position while attempting to predict your next input...imagine a tennis player waiting for a serve.
That board is the programming tool to change the tx/rx mode.
Old 03-06-2017, 09:01 AM
  #75
Team Tekin
Randy_Pike's Avatar
Yeah it would be nice if they were cheaper. But out of all the radios I've ran in my 20+ years in r/c. I've only had ONE Ko receiver go bad and it wasn't the receivers fault. I snapped the chassis testing ESC's and the receiver was physically damaged from the breakage..hard core.
