Like Tree6Likes
KO PROPO EX-RR
Old 01-04-2017, 07:26 PM
  #31
Originally Posted by Randy_Pike View Post
Mine doesn't do this at all. I'd suggest contacting KO and asking them what to do with it.
How do you like the radio? Is it the best you've used? most connected?
sn47som1 is offline
Old 01-05-2017, 10:32 AM
  #32
Team Tekin
Randy_Pike's Avatar
It's pretty damn solid to be honest. It's faster than my Ex-1 if you can believe that to begin with. I really like the new receivers. The foot print is a tick larger, but they're lower CG and the molded in antenna post is slick as hell.
The menu is different layout wise but it's easy to get through and everything does make sense. My only complaint is I wish the display had the tilt feature of the Ex-1. But it's a very minor complaint and I'm sure I was one of few that actually used it lol
Randy_Pike is offline
Old 01-06-2017, 09:09 AM
  #33
Only problem I have is that additional receivers are 165 Bucks!!!
Bubonic-X is offline
Old 01-06-2017, 09:51 AM
  #34
Team Tekin
Randy_Pike's Avatar
You can use your current KO receivers just fine, FYI. The new ones are required to get the best speed out of the new "Grasper" servos.
Old 01-06-2017, 08:33 PM
  #35
but how does the trigger and wheel feel? compared to others?
sn47som1 is offline
Old 01-08-2017, 05:20 AM
  #36
Default HCS
Anybody tried HCS mode on an RSx2 servo? If so did it work and could you feel a decrease in latency?
Magnus75 is offline
Old 01-08-2017, 08:08 PM
  #37
I emailed Ko Propo about the issue 2 days ago. No reply yet. If I don't here from them this week, I'll call. This is my first product from them. Anybody have any experience with their customer service?
Magnus75 is offline
Old 01-13-2017, 07:51 AM
  #38
Also try Joe at absolute hobbyz he may have some insight for you.
sn47som1 is offline
Old 01-13-2017, 10:08 AM
  #39
Team Tekin
Randy_Pike's Avatar
The wheel is the same as the Ex-1. I used my same 3d module to drop onto the Ex-RR
The trigger is typical KO Propo, simply the best.
Old 01-13-2017, 10:09 AM
  #40
Team Tekin
Randy_Pike's Avatar
Reach out to [email protected]
If they don't respond in 72 hours reach out to Absolute Hobbies their current distributor.
Old 01-16-2017, 06:57 AM
  #41
thats what im talkin about buddy! what lipo are you running?
sn47som1 is offline
Old 01-17-2017, 08:01 PM
  #42
They did respond and basically said the rattles are from the buttons. Also the springs necessary for the modular KIY system will rattle per KO. It is what it is. I like the radio, but it's like buying a high-end luxury car and the doors rattle when you close them.
Magnus75 is offline
Old 01-18-2017, 09:45 AM
  #43
Team Tekin
Randy_Pike's Avatar
I believe this is the one I'm using: HERE
Old 01-18-2017, 12:54 PM
  #44
LOW ET's Avatar
Trader Rating: 103 (100%+)
are you fully charging the lipo or only up to a certain voltage like we had to do with the eurus?
LOW ET is offline
Old 01-19-2017, 09:48 AM
  #45
Team Tekin
Randy_Pike's Avatar
Full charge. You can choose the tx battery type in the menu.
