Like Tree6Likes
KO PROPO EX-RR
Old 12-14-2016, 08:55 AM
  #16
LOW ET's Avatar
Trader Rating: 103 (100%+)
Originally Posted by Bubonic-X View Post
LOW ET.... Where how did you get one? What was the cost?
https://www.absolutehobbyz.com/KO-Pr..._p_510447.html
LOW ET is offline
Old 12-16-2016, 01:44 PM
  #17
I understand that the Rx has special circuits to improve performance. But, 163.00 for a Rx!!!! That's ridiculous! There are total radios that don't cost that much!
Bubonic-X is offline
Old 12-16-2016, 01:46 PM
  #18
LOW ET's Avatar
right, big money. i was like YIKES when i seen that.
LOW ET is offline
Old 12-16-2016, 01:47 PM
  #19
So basically I have to buy another radio to race another vehicle
Old 12-17-2016, 05:21 PM
  #20
LOW ET's Avatar
does anyone know if someone sells a fitted (pre-cut to the radio shape) foam transmitter case insert for the ex-2/ex-rr radios?
LOW ET is offline
Old 12-17-2016, 08:01 PM
  #21
Also very interested in this ..
aussie372 is offline
Old 12-27-2016, 07:50 PM
  #22
Trader Rating: 18 (100%+)
Just found out the servo neutral is 0.375ms when HCS is enable. Normal mode is 1.5ms. Sanwa is 0.297 ms. so sanwa may have faster frame rate but KO will may have less erro because of it dual receiver. will report back when I hook up the ex-rr to my vrc adaptor and compare to M12s data.
cup racer is offline
Old 12-28-2016, 04:02 PM
  #23
jdawg81's Avatar
My EX-RR came with two KR-415FHD receivers with long 210mm antenna wires instead of the short one at 90mm. Is it ok to trim the wire down to the shorter length?
nashwarrick likes this.
jdawg81 is offline
Old 12-28-2016, 11:50 PM
  #24
Default shorten the antenna
here is a thread about shortening the antenna.
http://www.rctech.net/forum/electric...r-antenna.html
the second last page should contain the answer you are looking for.
I think what it said is: basically the front part of the antenna lead is a shielded coxial cable and the last 31mm unshielded tip is used to receive signal. You can trim the antenna lead to the length you like and leave the last 31mm unshielded. Of course the higher the antenna, the longer the range. (i guess less error too ) Hope this help.url]
Old 12-31-2016, 08:57 PM
  #25
jdawg81's Avatar
Thanks, looks like I will need to open the receiver case to shorten the antenna and solder the trimmed wire to the pcb. I think for now I will leave it as it is.
jdawg81 is offline
Old 01-01-2017, 08:49 PM
  #26
Default EX-RR rattles
Every component of my EX-RR rattles if I shake it...like there are loose paper clips in it. The dispay unit, the radio unit, and the wheel assembly all do it. Seems to work ok. Very annoying and cheap sounding though.
Anyone else have this issue? None of my cheap RTR radios do this.
Magnus75 is offline
Old 01-02-2017, 09:32 PM
  #27
and to think i was just about to pull the trigger on one of these. that is such a bummer. how ridiculous is it that the highest end radios always seem to have rtr tx-like issues and even more funny is that rtr tx a lot of the time don't have these isolated and random annoying issues but the f****n $500 radios do?!!! its so azzzz bakwards. They really gotta turn things around its embarrassing for everyone in rc
sn47som1 is offline
Old 01-03-2017, 10:52 AM
  #28
Team Tekin
Randy_Pike's Avatar
I'm sure KO will have an insert for their own radio box soon enough.
The Ex-1 is a damn close fit if you need one ASAP.
Rp
Randy_Pike is offline
Old 01-03-2017, 10:54 AM
  #29
Team Tekin
Randy_Pike's Avatar
Mine doesn't do this at all. I'd suggest contacting KO and asking them what to do with it.
Old 01-03-2017, 11:00 AM
  #30
LOW ET's Avatar
Rp
cool, and thanks for the tip on the EX-1 foam.
LOW ET is offline
