New Sanwa MT-44 4-channel 2.4GHz radio system
#166
Got a question about the new receivers can a receiver be faulty ? I mean I know it could be faulty if it doesn't bind or power up . But can a receiver burn out a servo ? Pulling at straws but I had to ask . Race tomorrow and still haven't found anything wrong with the car or end points .
The other possibility is that you've bound the receiver in SSR mode, which some servos could potentially think is a far far left signal, and burn out because they're not able to turn that far. I'd hope that servos are protected from doing that sort of thing, but I guess it's possible.
#167
I think it would be tough for the receiver to burn out a servo as long as you're not applying High Voltage (i.e. either not through a BEC, or with a BEC set to 7.4v) to a standard voltage servo. The receiver can only pass on the voltage that it gets itself, it doesn't have any circuitry to change the voltage.
#169
In terms of race time, this means 36 minutes, plus testing, which was about the same.
#170
So I ended up buying this transmitter on Thursday. For the most part it's really nice and priced perfectly for my pocket. The only drawback I will say is the required AAA batteries.
I only used it Thursday evening of putting in 6 models in the memory and going through the screens to get familiar with. I raced with it first time yesterday (4-11pm with 4-heats and 2-mains and maybe 4 practice sessions) and the battery warning just beeped.
If it's going to take a few months to get a Lipo, I may have to try the Eneloops
#172
So I think everyone (including me) is missing a trick here... The MT-44 does require lower voltage, so a 4-cell NiMH pack wouldn't work... but what about a 3 x AA pack?
I just took the battery cover off mine, to take a look at the space where the Sanwa LiPo that I ordered (from Japan) will go, and I noticed that there is some foam padding around the AAA holder in the base. If you remove this, there is, I think, enough space for a 3 x AA pack like this: http://www.frys.com/product/2965525. I might pick one up and see if I can make it work, because this will give a pretty long run time I'd have thought, and I have plenty of AA Eneloops. I'm interested to see how much it impacts weight as well.
I've ordered the Sanwa LiPo already, so I'll probably end up using that, but I thought this was an interesting idea anyway.
#174
Does anyone know if the small wheel from the M12 will the MT44?
#177
