New Sanwa MT-44 4-channel 2.4GHz radio system >
Like Tree126Likes
Old 12-10-2018, 01:23 AM
  #751
Hang_TiMe's Avatar
Originally Posted by vetting View Post
Hi, I just bought the MT44, and like it alot. I drive Nitro (1/10) offroad and gas (1/5) offroad. I have little knowledge of elctric cars.
I have an old HPI Wheely King, that I thougt my son could mess around with. The original ESC and recevier on the Wheely King is not working, so I have to buy a new set. Is there a cheap ESC and reciever combo that will work with my MT44? I don't want to spend $200 on the Super Vortex, since it is an old Wheely King that my 5 year old son should play with Also, this is the only electric car I have, so I will not use the ESC and reciever on any other cars.
All help is much appriciated.
PS, sorry for my bad english, I'm from Norway
Practically any ESC will work with it. For the receiver, either go with the official sanwa ones, you can see the list here or search the net for the 3rd market ones. The 3rd market ones are cheaper so if it's just bashing then it'll work.
Hang_TiMe is offline
Old 12-10-2018, 08:02 AM
  #752
JC3
JC3's Avatar
Originally Posted by Hang_TiMe View Post
Did you track the hours?
No, I don't even know where to look to see the hours. Will look later however I don't think I ever reset it when I put the Lipo in. We'll see.
JC3 is offline
Old 12-10-2018, 12:21 PM
  #753
i just picked up an mt44 on black friday and was finally able to sort out what i needed to do to update the firmware. The micro SD card that I have is a 128gb sandisk card that has been reformatted to 64gb fat32. i was able to use this card to update the firmware to the current revision.
However the main reason that I upgraded from a mt4 to this transmitter is the 250 model memory when using an sd card.
i followed the instructions from the link below and was not able to copy a model to the sd card. I downloaded the file that your supposed to and the extracted the data from the card. I created the Model folder (also tried all caps and all lower case), and then put the modelex.dat file in the model folder.
When i went to go copy a model that I had already changed the name on to the micro sd card, it would go to the micro sd screen but would then go back to the transmitter model list. Any idea what I am doing wrong?
SANWA
c0bra is offline
Old 12-10-2018, 03:11 PM
  #754
JC3
JC3's Avatar
SANWA
I've never tried this but can offer a comment. The thing that comes up over and over when it comes to sd cards is the format on them. I think it needs to be FAT32 as mentioned by an earlier poster.
JC3 is offline
Old 12-10-2018, 04:06 PM
  #755
bl4
bl4's Avatar
I am also having this same issue trying to update the code 10 templates firmware. Previously using the same SD card(class 6) to update the firmware got no issue.
bl4 is offline
Old 12-10-2018, 05:24 PM
  #756
JC3
JC3's Avatar
  1. Go to clock menu in system
  2. Scroll down to system 1 or 2, whichever you wanna reset.
  3. Hold down scroll wheel then select yes.
I used these steps to reset the battery life timer - ON TIME1.
The second selection ON TIME2 can not be changed. The manual says that ON TIME2 is a "guideline for overhaul of the main body unit." Whatever that means! Right now my ON TIME2 shows 0084:11. Before I reset ON TIME1, it was showing the same thing 0084:11. Resetting ON TIME1 did not change ON TIME2. Also, there is no "system 1 or 2" available in this menu.
JC3 is offline
Old 12-10-2018, 05:50 PM
  #757
Hang_TiMe's Avatar
My bad. I meant on time 1 or 2 / Yes, it won't change on time 2. Only on time 1 can be changed.
JC3 likes this.
Old 12-11-2018, 12:41 AM
  #758
Thank you
vetting is offline
Old 12-11-2018, 03:52 PM
  #759
As I mentioned, the sd card already is formatted to FAT32.
c0bra is offline
Old 12-12-2018, 09:03 AM
  #760
JC3
JC3's Avatar
Did not see that, my bad.
JC3 is offline
Old 12-12-2018, 09:47 AM
  #761
Its alright. I am going to try and mess with it again tonight and try and figure out what is causing the problem. If i figure it out, i will let everyone know what I had to do in case somebody has a similar problem
c0bra is offline
Old 12-12-2018, 02:04 PM
  #762
lexusbest's Avatar
JC3 likes this.
lexusbest is offline
Old 12-13-2018, 05:26 PM
  #763
Originally Posted by lexusbest View Post
You put a female charge port across the battery plug? I was working on that so I could run the plug through the rubber grommet which would enable the battery to charge without taking it out of the radio? You follow?
Bubonic-X is offline
Old 12-13-2018, 10:37 PM
  #764
lexusbest's Avatar
haven't put any plug yet, will check that
Old 12-14-2018, 11:06 AM
  #765
Just got the battery should have it done by this weekend. Only thing that I'm concerned about is what if you turn the radio on while its charging? Will it go poof!
