Like Tree10Likes
Futaba 4pv
Old 11-29-2018, 10:47 PM
  #136
performula's Avatar
Fastest/Torquiest servos to run with the 4PV? Holy cow the Futabaís are expensive and out of stock!
performula is offline
Old 12-02-2018, 02:12 PM
  #137
1/8 IC Fan's Avatar
Trader Rating: 76 (99%+)
Torque wise the Protek 160T is a sure thing, I run it in 1/8 Truggy, 1/8 Buggy, 1/8 Onroad and 1/10 ST. Its great. If you watch tower hobbies, the OS Speed servos sometimes are on sale and are just re-badged Futabas!
performula likes this.
1/8 IC Fan is offline
Old 12-03-2018, 03:37 AM
  #138
performula's Avatar
thank you!
Old 12-10-2018, 05:49 AM
  #139
performula's Avatar
I have not dug into the instructions let alone opened this, however, I will be running 6S and would like to turn the power down since apparently Iíll be rooster tailing asphalt. What adjustment should I be looking at on throttle, EPA?
Old 12-13-2018, 11:28 AM
  #140
Lower values on Throttle speed and EPA. Maybe just EPA. Start around 85% and adjust from there.
Evoking1230 is offline
Old 01-10-2019, 08:20 PM
  #141
Trader Rating: 21 (100%+)
How do I set the DT buttons to where they won’t change settings when accidentally touched? I can’t figure it out for the life of me and can’t find it in the manual.
rcmoe is offline
Old 01-10-2019, 08:40 PM
  #142
You can go into the D/R ATL then SW/DIAL menu and for each of the switches that you want to disable, set them to 'off'. Page 72 in the manual.
mushroomed is offline
Old 01-10-2019, 09:16 PM
  #143
Ok I see. I thought maybe it had a function like the 4pks where you could just simultaneously press the minus and plus buttons without going into the menu screen. Thanks
rcmoe is offline
