Choosing a new charger
I'm looking for a new charger. I currently have 3 chargers and am considering switching to a single charger with multiple outputs.
The ones I'm considering are the Hitec X4
Hitec X2
Reedy 1216C2
I know the X4 has more outputs but less wattage per channel than the others. Could mean a slower charge time but the ability to charge all at once.
The charger I choose will primarily be charging 2s packs rated between 4000 and 5000mah.
I prefer to have an AC/DC charger to eliminate the need for an external power supply.
Any opinions would be appreciated.
Hitec X2
Reedy 1216C2
Hitec x2 is only 74$ shiped at towerhobbies sell ends on the 19th..with members coupon..I just ordered an x1 pro.. but tempted to get the x2 also due to price..
I absolutely love my Reaktors. They are simply icharger clones. Actually sold off my thunder power chargers to grab them. I prefer single output chargers and just but multiple in case something happens on one of the channels your not stuck with something that half works.
...maybe the answer is just a bigger pit table
I love my Dynamite Passport Ultra Duo... I've been considering upgrading to a powerlab DUO, as My charger max's out at 4.30v per cell... In my boat, I run revolectrix packs that can be charged to 4.35....
I just bought a UP120AC and couldn't be happier with it. Got it for $118 on amazon and as far as I can tell its the same as the Reedy 1216C2
When you have a less powerful charger you end up buying two batteries for each car. If you buy a better charger, one that can go to at least 10 amps, it will charge fast enough so that you can use one battery per car. This has been my experience. I use a HP 750 watt power supply, and an I Charger Junsi 206B. It can do 20 amps and makes short work of 4S systems. I also use a Reaktor(HK)250 watt charger as well for my 2S packs, both powered by the HP modified computer power supply. I use 9 amps on 2S, and 12 amps on 4S. It is very fast!
