Is my Radio broken?
Old 08-25-2016, 04:17 PM
Trader Rating: 9 (91%+)
Unhappy Is my Radio broken?
Hi,
Here is a link to video showing how my radio has started to operate.
https://youtu.be/tOuN8Mm5f1s
Your can see that throttle hover on brake/reverse and steering input seems to affect it. Notice also that I do not get full throttle. Also notice that steering left does not get full extension however right does.
I have reset the model and removed the module in case it was interfering.
My question is, is my radio stuffed or is there something I am overlooking?
I will be forever grateful if someone can help me as I like this radio and do not have the cash to replace it with anything similar.
Thanks in advance for any help.
BluWhale is offline
Old 08-25-2016, 06:05 PM
gigaplex's Avatar
I don't know the details of this particular model, but some radios support mixing channels together that behaves similarly to that. One use case would be using two steering servos for 4 wheel steering. Perhaps you've accidentally enabled this?
gigaplex is offline
Old 08-25-2016, 06:09 PM
Hi gigaplex,
Thanks for the response
I did think of that and checked to confirm no channel mixing is happening and to ensure that I reset the model to confirm that it is back to defaults.
Thanks,
BluWhale is offline
Old 08-30-2016, 04:01 PM
B16A2's Avatar
Select a new model, create a new default model regardless of binding to a receiver and see if it still does it.
B16A2 is offline
Old 08-30-2016, 06:19 PM
Just tried it and no difference, not looking good for getting my radio back
BluWhale is offline
Old 08-30-2016, 08:18 PM
whitrzac's Avatar
Trader Rating: 97 (100%+)
No. I'm seeing the nitro idleup function active and the steering/throttle mix active.
whitrzac is offline
Old 08-30-2016, 08:24 PM
So I just pulled it apart, figured I'd check contacts on the pots etc and it's all good.
Not sure f there was a pinched wire somewhere or what but she's good as gold.
Thanks for everyone's input.
BluWhale is offline
Old 08-30-2016, 10:22 PM
good to hear.
morryeclipse is offline
