-   -   Help with ESC problem (https://www.rctech.net/forum/radio-electronics/958171-help-esc-problem.html)
mamdot91 08-21-2016 09:38 PM
Hello everyone. I have 2 castle sidewinder SCT ESCs and they are both experiencing the same problem.
They function fine, they perform perfectly fine with ON. Problem is, that they dont always turn ON.
I have to try multiple times, pushing the switch back and forth until the lights finally turn on and the esc starts working. Yesterday I kept on trying for 10 mins and one ESC just wouldnt turn ON.
Why am i experiencing this problem, and how can i fix it??
Again, when ON they work just fine, but turning them ON seems to be developing into a problem.
francomang 08-21-2016 11:08 PM
Make sure your throttle trim is at zero. The esc won't turn on if it no at zero.
mamdot91 08-22-2016 12:41 AM
If that were the case then why would it turn on after multiple attempt? As in 1/15 attempts it works maybe??
And i will troubleshoot this when i get home ... just wondering what else could be causing this in case throttle trim is not the issue...
rustyus 08-22-2016 08:53 AM
My Castle Creations ESC starts vibrating the motor; with a melody, when turned on. Get a multimeter and test the switch circuit. Switches do wear out.
If you find the switches are bad...snip them off and solder the on/off switch's red and black wires leads together for the time being.
dtr 08-22-2016 10:44 AM
Those switches do not like dirt. Either replace them or just solder the two input wires together.
mamdot91 08-23-2016 12:41 AM
oh interesting.
So if i cut off the switch, and just solder the two wires (red/black) together, it'll complete the circuit? Meaning itll always be ON?
This could be useful ...
dtr 08-23-2016 12:35 PM
Originally Posted by mamdot91 (Post 14645325)
oh interesting.
Yes, as soon as you plug in the battery the esc is on. That's how I ran mine, and now do the same with a MMP.
mamdot91 08-23-2016 09:43 PM
I just did this ...
I hope this wont cause any problems in the long run?
Since the battery is only 2s, im not as afraid plugging it in as I wouldve been with a 6s. Haha
