Does receiver voltage increase range??
I'm trying to get more range out of my Futaba 4PLS. I'm running either 304sb's, 203GF's, or 2008sb. I was hoping that the 2008sb would increase range a bit, however it seems to be about the same. In some recent searching/ testing, Ive noticed that if I power my receiver with a 2s lipo RX pack(from my nitro cars) I seem to get better range. Typically I run the internal ESC at 6.0v.
Does this seem to make any sense? Thanks for any experience, or different idea's on more range. I didn't want to invest in a 4PX/4PX-r unless i'm guaranteed more range. |
It is weird because inside the receiver there is a voltage regulator making a steady voltage for the electronics.
Originally Posted by Roelof
(Post 14643085)
Exactly my logic, however, by setting the bec or external voltage higher, the servo/ electronics obviously get more V. I was just wondering if that somehow ups the range as the Rx side sees more V. I wish futaba listed ranges, but I guess there are too many factors... Ideally I'd like to have 1/2mile |
Maybe the voltage drops are less.....
RX, I don't think you are able to do that, its already a voltage regulator for servos and ESC. You can maybe do it with the TX. Radio operators of HAM and CB call it peak and tweak. Maybe Illegal to do. Radio systems of RC Futaba and Sanwa are different, each proprietary. One manufacture does better then the other.
FCC compliance come into the picture. Tweaking TX could cause static on home cordless phone that use 2.4mhz which RC runs. Cordless phone are regulated to 120ft from base, and also WiFi wireless on computers. CB limited to 4watts, 2 on walkie talkies. TX and home phones even less. Be kinda funny when you are messing around on the street, and neighbors phones ringing!!!! |
Originally Posted by Geezatec
(Post 14643451)
Originally Posted by Lanky
(Post 14643047)
Does this seem to make any sense? Thanks for any experience, or different idea's on more range. |
Originally Posted by howardcano
(Post 14643475)
Yes, that can make sense, and I've had similar results in the past. The battery is a "clean" source, i.e., free of electrical noise. Some receivers don't reject power supply noise as well as they should, and will therefore have more range when run from a battery. It's not necessarily the extra voltage that does the trick, but the lower noise.
now all I need to do is figure out how to get some more power out of the Tx side... :)
(Post 14643113)
Originally Posted by Andy Koback
(Post 14643527)
Seriously??? Lucky you can see that far leave alone drive a car/truck that distance! That'd be like looking at a fly on the neighbors window across the street!
When running my boat I have had similar issue's as well... easy to get it far out. |
I have noticed a lot less issues when running high voltage batteries in the TX. I am sure others have gotten a lot better performance going to higher voltage batteries as well.
(Post 14643538)
this specific application is for doing speed runs.. typically we do it at night utilizing lights.... typical distance of run is .45/mile or .9 total... crazy how much distance you can cover going 160mph....
I am running the LiFe 6.6v pack in my transmitter....
Originally Posted by EJ2civic
(Post 14643465)
Hahahaha...."legally" limited...I used to peak and tweak CB's when I was in that hobby. In addition, I also had "HAM" amplifiers that were also modded for use in the 27Mhz band of CB. Dont get me started on the "HAM" radios that are modded to include the CB band..:sneaky::sneaky::lol:
