-   -   Sanwa Super Vortex Plus Zero (Built-in RX-472) (https://www.rctech.net/forum/radio-electronics/946026-sanwa-super-vortex-plus-zero-built-rx-472-a.html)
CH121S 06-01-2016 02:01 AM
Anyone have any bad experiences?
Someone brought up the point if either esc or RX failed... your out for both.
Seems like a cool idea. But scared if any other downsides to the combo...
dstidham 06-01-2016 04:59 PM
I am interested as well. Following.
DirkW 06-02-2016 04:28 AM
Sanwa is well known for world class radios (Tx and Rx) and servos. It does not (yet) have much of a name for ESCs. That is the only "negative" (if you'd even call it that) I can think of besides the already mentioned down side of having two devices in one box. But for me it's enough to not try it (yet).
SLOWINSLOWOUT 06-02-2016 06:42 AM
Considering the cost is comparable to other mid/high end ESC's, its like you are getting the Rx for free, so from a cost perspective, its a great deal. Also, from a cost/failure point of view, no difference then any other ESC failing.
I ran one in a 4wd buggy, also have used a non-plus in various on road applications, all worked well, super easy to adjust via the Tx.
One thing to consider, I do not think the Plus is ROAR legal for stock blinky racing, and never will be I suspect. With the non plus you need to use a 471(no SSL) in order to be legal.
