Budget Servo that will fit B5M
Lots of people run this one, cant beat the price ($20)
https://www.amainhobbies.com/spektru...OJJhoCFxzw_wcB
or for 50
https://www.amainhobbies.com/protek-...-100ss/p253591
or for 50
or for 50
or for 50
Tactic TSX40 is cheap and probably the lowest spec servo I would use in a B5M. Metal gears, 0.13s, 99 oz./in @ 6V, $22. Only weighs 51g too, lol. My neighbor uses one in his B5M.
servos from rc juice.com. you can buy them on there website or ebay
http://www.ebay.com/itm/K-Power-DMM-...MAAOSwf05XO-4Z
http://www.rcjuice.com/radio-equipment-servos/
K-Power DMM-150 Digital Metal-Gear Servo, Waterproof High-Torque RC Car Truck
With metal gears, dual ball bearings and a heavy-duty aluminum housing, the K-Power DMM-150 digital servo provides plenty of torque with good speed.
Specifications:
Speed @4.8V: 0.15 sec
Speed @6.0V: 0.13 sec
Torque @4.8V: 215 oz/in
Torque @6.0V: 226 oz/in
Dimensions: (LxWxH) 40x20x39mm
Bearing: Dual ball bearing
Gears: Metal
Motor: Digital
Input Voltage: 4.8V-6.0V
Output Shaft: 25T spline
Wire Harness Length: 305mm (from case to end of plug)
Specifications:
Gears: Metal
Motor: Digital
Good choice. I put the protek 130T in my buggy, as the track didn't carry the SS. The numbers are supposedly the same as my savox on the speed side, but wow, what a difference. It was WAY faster. I don't know if Savox is slow, or if Protek is super fast for the specs... only 2 I've ran..
I've had great work with my Savox 1258's in mutiple buggy's and stadium trucks. Good budget servo in the 40-60 range depending where you buy and discounts offered.
