Wireless Sensored Motor and ESC's
We all know what it's like to have a sensor wire go bad mid race, it sucks! Also, how many times have you gone into the shop only to find out that the sensor wire length you need is sold out. Well, let's get rid of them! I'm sure motor companies are trying to figure out a way to make motors use a bluetooth sensorboard and go wireless instead of having to use sensor wires. They're coming, but when? One, two, three years? Also, how about removing all of the A, B, C wires from the motor/ESC. I would think that by now, the technology exists to simply have the + and - battery wires to the esc and one single wire from the esc to the motor and completely eliminate the need for the other 3, combine that with a bluetooth sensor board, then wiring would be so much easier, cleaner and more reliable having fewer posts and areas of contact to go wrong. Electronics have gotten better and more reliable, but the actual technology seems to have gone stagnant. I'm sure I'm not the only person who thinks about these kind of things, what would you guys like to see in the near future?
Oh and one last thing...Isn't it time to do away with the super small balance port wire for Lipo battery's and make them bigger? They're tiny and break way too easily!
He probably didn't read your post, just the title, and is now referring to Hobbywing's WiFi module (which only replaces the programming card, but has nothing to do with sensor cables or wiring up the motor differently.)
Wireless data transfer is slower and less reliable than wired, if the sensor data can't reach the ESC in due time or arrives corrupted it would be even worse than a sensorless design. Any error correction or size reduction measures would increase time it takes to decode sensor information immensely.
The technology exists of soft start like sensored with a sensorless design, it's a homebrew ESC that in many ways is better than most name brand ESCs.
What you speak of seems like a motor with integrated ESC, like the Team Orion D drive
True. The latency of wireless tech alone is probably the biggest problem of all.
