Turbo, boost, and timming slope explained help?
I run a Orion R10 Pro and Trinity motors, can some one help explain boost, turbo timming, and slope timming?
I've tried to Google and I cannot find any info, that really explains how all this works. If I run 30° timming on the motor can, does the Orion R10 Pro add more to it with boost? I'm confused. Should I leave the motor timming at 0° and let the R10 Pro do all the boosting? |
If you're not going to run blinky, then yes put the timing on the can to 0. Check the instructions for your motor though as some motors aren't actually at zero when the can says 0.
I will set them all to 0° and check to confirm on motor checker.
What will a Team Orion R10 Pro Turbo boost to default? I do not run stock class as of right now. |
| All times are GMT -7. It is currently 11:19 AM. |
