Help identify this motor
Thing has been punished for a good 6 months and I bought it used. Been a great motor.
Are the windings supposed to come out of the can like that? I see no glue or anything so I assume so. I'm trying to order a sensor board and bearing but they only list M3. Pic looks like it will work but thought I'd ask in here. This motor doesn't look like M3. http://img.photobucket.com/albums/v2...32949.png.jpeg |
It's probably the M2 version. (prior M3) That's how they come apart. You can buy different stators and use the same can. (7.5 to a 10.5 etc.) I'm guessing the bearings would be the same but you'd have to measure the ones you need and compare.
The bearing doesn't come out of the sensor board. You have to buy the whole thing.
Ok. The bearing comes out. All good.
That's the original Reedy Sonic (not any of the Mach Versions). It uses ASC972 for replacement bearings. Amain has them available or your LHS should be able to order.
I have one in 17.5, they were good motors in their days. |
| All times are GMT -7. It is currently 09:44 PM. |
