-   -   Need help with ESC (https://www.rctech.net/forum/radio-electronics/936144-need-help-esc.html)
Pao44445 03-29-2016 04:46 AM
Need help with ESC
I bought some waterproof brushless combo (ESC+motor)
I think there is a problem with setting in this ESC because
- Backward has much acceleration than going forward.
- If I change motor setting to normal, the car won't go forward
- If I turn off the transmitter first, the car will go forward slowly
- Weird throttle (unstable)
https://upic.me/i/rz/0newcanvas.png
spookie 03-29-2016 05:15 AM
- Backward has much acceleration than going forward. Reverse two motor leads
- If I change motor setting to normal, the car won't go forward Calibrate ESC
- If I turn off the transmitter first, the car will go forward slowly NEVER do this, always car off first
- Weird throttle (unstable) Perform above steps and get back to us
sakadachi 03-29-2016 08:12 AM
Yeah, sounds like your wires to the motor are reversed, or need to reverse polarity the throttle (channel 2) on your radio.
MarkA 03-29-2016 10:39 AM
Also, try re-binding your radio and then re-calibrating your ESC but mostly I agree with the above posts about the wires not being hooked up to the motor correctly.
