Muchmore fleta pro-issue
Hi all.
I have a muchmore fleta pro which seems to have an intermittent problem. Every now and again while driving, the esc will randomly restart itself, and re-calibrate itself. Now it normal does it when it has been sat idle for a little while, and then I go to accelerate again (like during the countdown for the start of a race, which isn't very helpful). It is running the expert v1.30 software, I have tried replacing the sensor lead, receiver, motor, even the servo. I've calibrating it before the run to see if that does anything, but nothing has fixed it. It was brought new and did it from day one. I own 2 other fleta pros and none of these do it, so I'm puzzled why this one does. Any help or input would be greatly appreciated. Many thanks in advance |
Have you tried turning off the temperature shutdown?
Originally Posted by dennisV
(Post 14462101)
I had an issue where the switch wire started to fray just where it exited the Alu housing which caused similar issues to what you describe. I had to remove the bottom case and cut and resolder the switch wire. This cured my particular issue.
Originally Posted by dan_vector
(Post 14464656)
| All times are GMT -7. It is currently 08:29 AM. |
