Traxxas 2.4 ghz radio and rec glitching? > Traxxas 2.4 ghz radio and rec glitching?
Old 03-23-2016, 07:10 AM
Default Traxxas 2.4 ghz radio and rec glitching?
I have a 2x4 traxxas slash with the stock radio and rec. Also has the velineon system in it. But it seems I cant go farther then 20ft and it just loses connection. The things I have tried to resolve:
- New batteries in the controller
- Check and triple checked the wiring for loose connections / found nothing.
Is there something Im missing here? or should I just bite the bullet and get a new radio system.
1stplace is offline
Old 03-23-2016, 08:16 AM
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Did you try re-binding them?
MarkA is offline
Old 03-24-2016, 07:12 AM
no... I will try that next.
1stplace is offline
Old 03-24-2016, 01:44 PM
HBRob's Avatar
Trader Rating: 61 (100%+)
Likely a bad receiver or transmitter antenna wire. May have a knick in it. Is the original end still present or has the wire been cut in any way?
HBRob is offline
Old 03-25-2016, 08:07 AM
I had the same problem it ended up being the rx, rebinding or glitch buster did not help. I had the older tq system with the chrome wheel on it. Unfortunately it was only compatible with only one rx and that rx was 50 dollars. So I looked at it being a excellent time to upgrade. I went to a dx4c for 89.00 and never looked back.
Geeves is offline
Old 03-30-2016, 11:57 AM
Well, I tried rebinding and it solved the issue.
Thanks!
1stplace is offline
