Like Tree35Likes
Hobbywing xr10 pro
Old 07-02-2016, 11:59 PM
  #76
got two of these bad boys, very nice! Very very smooth!
Cmgreen is offline
Old 07-03-2016, 02:44 AM
  #77
gavaust's Avatar
Trader Rating: 22 (100%+)
Mines awesome played around with the settings in 4wd mod buggy mainly the freq settings and a few others very impressed the video on YouTube is really well explained after you watch it a few times 👌
gavaust is offline
Old 07-04-2016, 10:15 AM
  #78
Trader Rating: 24 (100%+)
Medulla will there be a 1s version of this speedo? If so, any ETA on availability? Trying to get my ducks in a row for 1/12 this winter!
fenton06 is offline
Old 07-04-2016, 01:38 PM
  #79
Madulla's Avatar
I am not sure about a 1s version. I am not in that loop. I will be as surprised as you when/if they announce it. You can use a XR10 with a 1s booster. Just remove the red wire from the esc plug. That way you can use it on a 12scale or TC.
Madulla is offline
Old 07-04-2016, 04:19 PM
  #80
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
Any hints on getting it to work with my program box? Just says "connecting to esc"
TeamCarnage is offline
Old 07-04-2016, 06:37 PM
  #81
B. Santos's Avatar
I believe the firmware on the program box needs to be updated to the 4.0 revision.
Linking to the esc takes about 10-15 seconds for me.
B. Santos is offline
Old 07-07-2016, 02:20 PM
  #82
So I updated the Program box and still the same connecting esc message. I made a harness to connect the esc to the program box. Turned the Tx and esc on and all works as should. Thanks for the help!! GoodRacing!
Old 07-11-2016, 01:08 PM
  #83
In Mod TC, anyone try Hybrid brakes? Thoughts?
LAGuy is offline
Old 07-11-2016, 01:14 PM
  #84
romanmotruk's Avatar
can someone lay out the data logger? or are they only in the controller program? make a print screen please!
romanmotruk is offline
Old 07-11-2016, 05:05 PM
  #85
SpidarX's Avatar
Thumbs up
Originally Posted by rekim View Post
Haha
SpidarX is offline
Old 07-14-2016, 11:12 PM
  #86
Hi guys just a quick one I've just got my xr10 pro and on reading the manual it says about selecting the sensor mode,full sensored or sensor less/hybrid and that if the esc is used in full sensored with a non Hobbywing motor it car damage both items.
So my question is my old 3.1 never said any of this and I'm curious if anyone is running a different brand motor and if there are any issues
rossman is offline
Old 07-15-2016, 02:33 AM
  #87
howardcano's Avatar
Trader Rating: 37 (100%+)
The warning is only for four-pole motors. The manual states:
"Warning! Do not select the option 1 if you are using a non-Hobbywing matching motor, when it’s a 4 pole sensored motor, otherwise you may damage your ESC and motor."
If you are running a two-pole motor, any brand having the ROAR-specified sensor connector configuration should be fine.
I have no idea why there is a warning for four-pole motors. I'm also curious to hear from anyone that has tried one.
howardcano is offline
Old 07-15-2016, 11:15 AM
  #88
Trader Rating: 30 (100%+)
Dang, I had the Hobbywing WiFi express on backorder through HW NA and just got an email that my backorder was cancelled due to programming "development" with the app. Their new expected ship date is sometime in August.
I was looking forward to using this with my XR10 Pros. I'm going to have to find a way to update to the latest software using the program box w/o a Windows pc.
AMessy is offline
Old 07-15-2016, 12:50 PM
  #89
dawgmeat's Avatar
Originally Posted by SpidarX View Post
Where are people putting the capacitors on their touring car? I cant see where Bruno has put them.
Mines sit between the Motor and ESC
dawgmeat is offline
Old 07-18-2016, 11:11 PM
  #90
"Warning! Do not select the option 1 if you are using a non-Hobbywing matching motor, when itís a 4 pole sensored motor, otherwise you may damage your ESC and motor."
Thanks for the reply I must have missed that part.
Cheers
Ross
rossman is offline
